Question about Microwave Ovens
My Birko 10L tempo tronic stop working. I think the thermocoil broken. How do I test and take off this part.
Mircowave works but doesn't work for heat/grill defrost etc
1.check fuse
2.check relay (microwave oven magnetron)
3, check switches of the doors
May 11, 2014 | DeLonghi P90D23EL-B1A Easi-Tronic Solo...
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Dear all, I have a micro-wave whirlpool VT255/wh. My mother complains about non regular noise when she starts oven . During my tests, the oven start several times without any problem. After a while, it...
one of Fixya experts has posted a possible solution, below.
" This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Originally by
MicrowaveSvc
Hope that helps.
May 30, 2011 | Whirlpool Microwave Ovens
Need instruction manual for Magefesa pressure cooker 4M69 Stainless steel 18/10, 6L 04006 06/01 made in spain. This is all the info on the bottom of the pressure cooker.
I have the same model. The following link matches this product:
http://www.e-magefesa.com/index.php?option=com_docman&task=doc_download&gid=122&Itemid=16&lang=en
I found this manual using the magefesausa.com website.
May 06, 2011 | Microwave Ovens
GE spacemaker microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stop working. The lite comes on and the timer works. The fan and turntable won't work.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Sharp Microwave Ovens
Broken microwave
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 23, 2008 | Microwave Ovens
Microwave Ovens Logo
323 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
