PDP42V5 No picture, Sound OK. HV 'crack' when relay switches in.
  • 3 more comments
  • SteveP6 Jun 14, 2008
    The actual TV is a Hyundai HPT 4240 but inside it uses LG modules and has the LG PDP42V5 part No.
    The sound is fine but the display is blank. I have replaced the 1uF, 630V capacitors C19 & C97 on the DGK 420W PSU PCB.
    That has not fixed the problem and there is one HV 'crack' or pop when the relay drops in.
    I cannot find a circuit diagram (schematic) or handbook with test points to allow further diagnosis. Can anyone help with Tips or data?
    Thanks.
    SteveP6
  • Oleg139 Oct 08, 2008
    I have the same problem.
    There is sound, but no picture at all.
    All outputs from PS DGK 420W are OK.
    On the Control board (CTRL_1222_TMDS) D17 is flashing, D13 and D2 are steady lighting.
    +15V on the connector P300 is actually only about 9V unless the cable is disconnected from Y_SUS board and +15 is measured on Y-SUS.
    The heat sink on the Z-SUS board is becoming hot for fingers pretty in 5 minutes after turning power on, but it may be OK. I do not have any schematics.
    Will anybody help please?
  • 2672 Nov 28, 2008
    The tv switches on but turns off after a few seconds. The output of the rectifier on the PSU is 340VDC. This lovers to about 230VDC untill the unit then enters standby mode. Any suggestions welcome!! Thanks.
  • tom togtokh Dec 31, 2008
    Yes I have a same problem Where I can find PSAnybody khows VIZIO dealer or online ?
  • chahn99 May 11, 2010
    Hi djtomeeee,
    Did you meant capacitors inside IPM (power module soldered on the board?)
    I have pdp42v6 panel and the Y-sus is 6871qyh029A.
    Recently I replaced Z-sys and Y-drive bottom to fix no picture but sound. It shows picture and sound, but there is also some flickering noise. And Z-sus 15V point produses about 12 V.
    Can you describe the part I should replace?
    Thanks
    President:
  • 749 Answers
Here's what you need:
1) General guide - very similar TV, same main issues and troubleshooting process:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
2) Most common repair for the pdp42V5 chassis:
http://www.coppelltvrepair.com/p/227/viore-pdp42v18ha-ysus-6871qyh053b-repair-service
Hope this helps!
Posted on Apr 15, 2013
  • 3 Answers
Replace the alu-case electroltics in the 15V-line of the Y-sus, they are connected to the inputs of the 15V regulators. I've repaired a lot of these modules. they are 33uF 25V types. I have replaced them with normal elelctrolytics in value of 47 uF/ 35V...
Best regards,
Thomas, Hungary
p.s.: Do not operate the display without these capacitors replaced because the IPM (hybride IC) on the Z-sus and Y-Sus can burn out...
Posted on Jan 22, 2009
  • marcelo0680 Sep 03, 2010
    how many 15V regulators do you have? I can see only 1
On an AIWA HV-MX100, black and white picture OK but why not color?
If the remote works then it works. You might be missing a few functions but I can't imagine that it's capable of switching to B&W. I might be wrong but I think that the TV needs checking.
May 05, 2015 | Aiwa Televison & Video
PDP42V5
power supply module located near horizontal yoke receptacles beneath a larger 5w resistor
Mar 20, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
RCA32V434T
The Horizontal Output transistor needs to be changed as it is most likely shorted. The current transistor on this set is a 2SD3402 (no longer available) it's new replacement part number is the 2SC5902.
Order 2 2SC5902 Horiz Output transistors.Replace the transistor by it self once and if all is ok then fine.
If not replace it again and also the the Flyback HV transformer. The HOT transistor is probably shorted again and the transformer is causing it.
Dec 27, 2008 | RCA 32V550T 32" TV
No sound and no picture
THE CLICK IS THE MAIN RELAY-THAT MEANS THE FUSES ARE NOT BLOWN---USUALLY PROBLEMS WITH THESE SYMTOMS IS HIGH DOLLAR TO REPAIR!! HV PARTS ,YOKE ETC....NOT GOOD!!!!!
Feb 11, 2008 | Sanyo DS27930 27" TV
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Feb 01, 2008 | Zenith B27A11Z 27" TV
No picture but sound
Hope this helps!
Jan 07, 2008 | NetTV PDP42V Television
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
KP-53XBR45, Sound OK, but no picture
You may have a bad convergence... short will shutdown your HV circuitry leaving just audio?
It has no bulb to change?
Oct 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Have sound and no picture
HI I HAVE THE SOUND BUT NO PICTURE BAT WHEN I BEND THE POWER BOARD OR PLAY WITH IT LEFT OR RIGHT THSN I GET THE PICTURE
Oct 02, 2006 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
2,635 people viewed this question
Top Televison & Video Experts
Electro Med Services...
