Question about Optoma PRO150S DLP Projector
White dots all over - Optoma PRO150S DLP Projector
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
White dots appear on screen
Sounds like your DLP chi is faulty
Jan 06, 2013 | Mitsubishi WD-57733 57" HDTV
Started out with 2 white dots and now have 13 white dots
Sounds like white dot syndrome. Read a article not to long ago on this. Heres a story I found on it good luck (",)
http://abclocal.go.com/kgo/story?section=news/7_on_your_side&id=7795687
Jan 06, 2011 | Samsung 61" Slim-Depth DLP HDTV
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
What does it mean that my 66 pony has a green dot trany?
the '65/'66 C4, was known as the "Green Dot" C4 & has a different shift pattern to the '67/later C4's.
So your C4 tranny is the green dot which is an UPGRADED option. A better tranny better gears and stronger parts and what not, there was also the white dot tranny that was the cheaper or less performance transmission. As far as i understand the white dot was available for better fuel consumption HAHAHA which no one really cared about in 66 anyways.
In '65/'66 it was something like this:
P - Park
R - Reverse
N - Nuetral
White Dot - Starts in 2nd, automatically shifts to 3rd
Green Dot - Starts in 1st, automatically shifts to 2nd and 3rd
Apr 18, 2010 | 1966 Ford Mustang
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots
There might be an issue either with your DMD board or your Video board, with the tv on, go to the menu, and if those white dots are still there the issue would be with your DMD board but if those dots magically don't show up on the menu, the issue would be with your Video board
Jul 22, 2009 | RCA R52WM24 52" HDTV Projection Television
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Optoma PRO150S DLP Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
