Question about Zanussi TD4212W Electric Dryer
I have replaced the capacitor on my dryer, and now starting and spinning perfectly, thank you. however, now there is no heat. Where the mains cable enters the rear cover, there is three plugs that connects to the inside workings, I thought I only disconnected two, is this correct, the one with just one connection is hanging free.? Could this be the cause?
  • Zanussi Master
  • 3,463 Answers
More than likely is the cause of your problem, you must reconnect it for it to work correctly.
Posted on Nov 04, 2010
I changed the belt on my samsung dv219aew/xaa dryer. Put the dryer back together tested once and worked fine. I put a load of laundry in and pressed start and then the power cut off. No lights to control...
if the belt snapped there is usually a reason
some jam up
check that and also there is a capacitor a round white tube
with two connections to it usually bolted too the motor
replace this part
you may find the heating system has a reset feature or thermal fuses
also you may need to replace the mains fuse in the plug or etc mains supply
i think as you put a load in and it cut out
then the start cap is prob short and has blown the fuse
Dec 07, 2014 | Samsung Dryers
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
Bosch dryer has heat but does not spin
Either the belt has slipped off or broken, or the motor start/run capacitor has failed.
Place the dryer on its face, with cushioning. Take off the back panel and look around inside. You will see the drive belt which is long and thin and should wrap around the drum.
http://pad1.whstatic.com/images/thumb/2/27/Change-a-Clothes-Dryer-Belt-Step-12.jpg/550px-Change-a-Clothes-Dryer-Belt-Step-12.jpg
If the belt is broken, replace it. If it looks OK, find the motor start capacitor, which looks like this. A failed capacitor will have a split or bulging case, or a displaced end cap. They are widely available on eBay or from appliance parts shops. Get one the same voltage and capacitance rating, eg 240 VAC and 8 uF or whatever.
http://www.capacitorguide.com/wp-content/uploads/motor-start-capacitor-300x212.png
Sep 02, 2013 | Dryers
My dryer stopped spinning and it won't heat. it just makes a click sound inside the dryer.
Dear Sir:
See this possibles causes:
Power from the house
Test the main cables from your house, and the dryer for continuity see the diagram attached
Heating element
one heatings elements burn or open, test for continuity.
Thermal fuse
test the fuse for faulty or open, continuity and replace it
Wiring
test for wires burn or break, see for continuity.
God bless you
5_24_2012_10_33_43_am.gif5_24_2012_10_33_58_am.gif5_24_2012_10_34_21_am.gif5_24_2012_10_35_06_am.gif5_24_2012_10_35_28_am.gif
May 24, 2012 | Samsung Dryers
What wrong with dryer when it shuts off after spinning for 30minutes and will not spin at all. dryer was working fine when it stopped drying clothes. It appear to have over heated then shut off...
Check if the motor hums once you turn on the dryer. If you hear a hum then check the starting capacitor if you have a multi-tester try to check if it's still in a good working condition. Replace the capacitor if its already damaged.
Dec 01, 2010 | Kenmore Dryers
My whirlpool special edition 3 cycle dose not turn on but it gets heat the belt is fine, it was working fine then one day out of the blue i turned it on and it was not starting noticed it was still heating...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Whirlpool LEB6200 Electric Dryer
No heat in the Dryer
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Dryers
Maytag Stack, Can't spin to start anymore
sounds like the motor capacitor
Sep 03, 2009 | Dryers
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Nov 14, 2008 | Fisher DEIX2 Dryer
Zanussi TD4212W Electric Dryer Logo
122 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
