I have just purchased a Beko WME7227W washing machine, it get stuck on the wash cycle & will not drain or spin? Initially we think the drain pipe was too low as the manual states it should be between 40cm & 100 cm off the ground, it is now at 86 cm from the floor and the problem still exists, I have had to manually drain the machine and have checked the filter even though it is a brand new machine. Any ideas.
SOURCE: MACHINE DOESN'T CYCLE OUT OF RINSE
my ariston margeurita washes but doesn't rinse.
Posted on Feb 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Posted on Jan 01, 2009
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
  • 41 Answers
SOURCE: Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Posted on Jan 09, 2010
My beko washing wont do a cycle instead jumps to spin then whilst trying to do a spin it jumps all over the kitchen
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. there are a few possibilities here see below
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 21, 2014 | Washing Machines
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
May 17, 2012 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Dec 30, 2009 | Washing Machines
Washing machine wont spin and only drains when it wants to
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Jun 19, 2009 | Washing Machines
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
