Question about Whirlpool Refrigerators
Whirlpool GNF 250X - Whirlpool Refrigerators
Galaxy 949/am s.s.b no receive on a.m mode
turn off the GNF so the signal can get through.If that doesn't work then try turning the squelch all the left . Its possible the squelch control inside the radio for AM is turned off .
Feb 13, 2018 | Galaxy Radio Communications
Our refrigerator whirlpool gnf 220x is not cooling
can you hear the compressor running? how about the fan check your thermostat control make sure it works or your defrost timer got stuck on defrost cycle and that why is hot...good luck
Oct 04, 2013 | Kitchen Ranges
Water is leaking from bottom of my Whirlpool fridge. Its GNF 286 X
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 27, 2011 | Whirlpool Refrigerators
Need urgently Door handle for whirlpool refrigator model GNF 220X
Check with Repair.Clinic.com. They have replacement parts for a large number of appliances. Step by step replacement instructions are also available. You'll need the approximate year of manufacture, model #, and serial # of the refrigerator.
Mar 06, 2011 | Whirlpool GS6SHAXMB Side by Side...
Cleaning of whirlpool gnf 220x model
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 20, 2010 | Whirlpool Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
What Oil to Use in My CRF 250X 2004
If you have the owners manual check that, otherwise ring a bike shop and ask them for advice.
Aug 20, 2009 | 2005 Honda CRF 230 F
Refrigerators Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
