Question about HP PSC 1610 All-In-One InkJet Printer
Printer problems HP PRINTER doing many strange things...........added new ink today and printed out 4 black and wnite copies. Eveything was fine ; now everything from carriage jammed to out of paper is coming up and nothing is jammed or out. Please assist! Thanks!!
  • jstorey Jun 24, 2008
    My problem seems to be a paper feed problem. It started with a cartridge jam error and nothing was jammed. When I feed in a single sheet it feeds the first sheet through and nothing prints. Then the next sheet feeds in about two inches then feeds in and out a inch like it doesn't sense the sheet then comes up with a paper jam error. When I put in a stack of paper it feeds in multiple sheets stacked together. I just can't get it to do a print job.
  • 56 Answers
Try to reset the device by turning the device off and unplugging it for a few minutes - then plug it back in and power back up. Sometimes being powered off will clear the jam sensors.
Posted on Jun 13, 2008
How do I make new cartridge print?
remove the cartridge and check that you have removed the tape across the print head
insert and press black button on the printer or next on the printer screen it should go to print test page which you then have to photo copy back into the printer so that it can realign the printer head .
Sep 06, 2015 | HP OfficeJet Pro K8600 Printer
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp c6180 Will not print in black.
Strangely enough, I have an Epson multi-use that has done the same thing to me. The boys at the shop said they had to practically replace the printer heads, but I got it home and it still did the same thing, so I'm inferring from this that it's a problem that wasn't forseen by the printer gods when they invented this contraption. I'm guessing somehow that it's not the black ink head that's bad, but probably the frame that holds it is bent or misaligned, and the printer lackeys are hiding this bit of evidence from the gods to avoid the shame, as I could never get a straight answer from any of them. Good luck.
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
