When i plug the dc juck no power light already dead
  • ProCode
    ProCode Nov 04, 2010
    do you hear anything?
    are all LEDs dead or does one flash once?
    did you check power supply for power?
  • 2,567 Answers
Please refer to the following article for a detailed diagnosis of your problem:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Posted on Nov 04, 2010
How do I fix my power adapter?
Could be the capacitors that filter the final D.C voltage in the power apadter . If the capacitors fail the D.C voltage would have 50 or 60 hertz hum on it. If a diode has failed it could also cause a more severe pulsing of DC voltage. A oscilloscope would show up if the DC is being distorted but I do not know where you would get access to one. A repair shop maybe ?
Jul 02, 2015 | Crosley Audio Players & Recorders
Power cable issue
It should be 32 volts DC ..this purple one only has two pins in it...now the gray one's have 3 pins..and I think it has 32 volts DC and 16 volts DC out...
Mar 05, 2014 | HP Officejet 6500 Wireless All-in-One...
Laptop battery light won't stay on
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
My battery light is off.
Jun 03, 2012 | Toshiba Satellite A105 Notebook
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | Advent 4211c Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Vaio will not turm on
you will most likely need to replace the dc jack, which is the port where your charger plug plugs into...
To test if your dc jack is bad... Remove the Battery, Plug the Power cord into laptop then attempt to power on... If no lights turn on, no fan spins.. your DC jack is bad...
DC Jacks Cost $6 to $10 but you need to find someone experienced to replace it, or you might end up with a dead motherboard as well..
Oct 14, 2008 | Sony VAIO PCG-V505DXP Notebook
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
WILL NOT PLAY FROM THE POWER DC PLUG
is it the right dc plug sounds like its not getting the right voltage
Feb 06, 2008 | Sony Walkman D-SJ301 Personal CD Player
Computers & Internet Logo
16 people viewed this question
Alun Cox
k24674
