Machine displaying code 3451 what does it need
  • Office Equip... Master
  • 2,386 Answers
The Fusing Roller Thermistor does not detect the required temperature within 30 sec. after a warmup cycle has begun; therefore, the copier does not complete the warm-up cycle.
The temperature of the Fusing Rollers does not reach the required level even after the set period of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Posted on Nov 04, 2010
My Bizhub C252 Konica Minolta is getting error C-3451? How can I fix it ?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Jun 28, 2017 | Konica Minolta Office Equipment & Supplies
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
How can i recover from this problem??
You did not mention the brand name and model of your photocopier machine.But C-3451 is usually the code related to fusing unit/Heater Section.In order to get rid of this problem you have to reset the code.After resetting if the code appears again, then there is problem with thermisters, heat roller.
Feb 20, 2015 | Konica Minolta bizhub Office Equipment &...
Error code 3541
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Dec 27, 2013 | Konica Minolta bizhub C250 All-In-One...
Need radio code for 2001 daewoo lanos
Hi Palmspringsv,
I recently had a Lanos towed into my repair facility with a dead battery. After replacing it we had the same problem,radio displays the word code. I found a website that posted the following codes as the most common for the US models. I entered them until I got down to 13th one and it unlocked it. Good luck,hope they help,Chuck.
4316 2152 4513 4362 1156 2145 3451 6361 5624 5241 3346 1165 3241 4524 5436
Sep 16, 2011 | 2001 Daewoo Lanos
Stereo does not work, dial reads, cod ? Is there a reset code to make the entire system go on?? I just bought this 2001 Nubia and the display lights up but that`s all.....
Try the last 4 digits of the radio's serial number (s/n or s#)
or try the following general codes:
4316 2152 4513 4362
1156 2145 3451 6361
5624 5241 3346 1165
3241 4524 5436 1165 4362 5813 4513 5241 4316 1651 5346 1341 3241 1652 4524 6361 2145 5436 1857 4353 5632 3451 1638 1156 1636 5324
Dec 09, 2009 | 2001 Daewoo Nubira
Need code for my all for one URC-3450/3451 for Kenwwod DVR-6200
Hi.
bought the same remote and asked here for a fitting code for my Denon universal-fernbedienung.net
Apr 09, 2009 | Televison & Video
Need raido code for 2001 daewoo leganga please
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451 3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653 5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461
Posts: 4 Radio Code List:
6361,LEGANZA 99
2253, 3116, 3451, 2152, 4362, 4316
4316, 4513, 4362, 1156, 2145, 1156
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 5624
2453, 3462, 3251, 5445, 8253, 1156
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4314
6234, 4356, 1415, 1435,1156, 1651
6361
2152 1165 4362 5813 4513 5241 4316 1651 5346 1341
1638 1156 1636 5324
Dec 09, 2008 | 2002 Daewoo Leganza
Need a radio code for my 2001 daewoo
4316
2152
4513
4362
1156
2145
3451
6361
5624
5241
3346
1165
3241
4524
Nov 10, 2008 | 2001 Daewoo Nubira
54 people viewed this question
k24674
jasbo
jasbo
