Question about Xerox WorkCentre Pro C2636 Color Copier
MACHINE IS NOT COMING TO READY POSITION.WHAT TO DO.XEROX WCP 2636
3 Suggested Answers
  • 2072 Answers
SOURCE: need to remove the finisher
Open the front door, there is an opening to the left under the transport . You reach in that opening and there will be a plastic block about 3 or four inches in the finisher. You pull that latch toward youself and that will inlatch the finisher from the machine.
Unless it is an office finisher in which you would have to remove thumb screws under a plastic cover on front, disconnect the plugs from the finisher to the machind and then lift the finisher up off the rails .
Posted on Aug 19, 2010
elix0411
  • 3530 Answers
SOURCE: what does a 3.382 and
Welcome to Fixya
Tip: You can print the service report from your printer. The report will tell you what is wrong with the printer. See procedure below:
1. Press the [Machine Status] button located on the right side ot the control panel.
2. Select the [Machine Information] tab located on the user interface (if not already
selected).
3. Select the [Print Reports] button located at the lower left on the [Machine Information]
tab. A new screen appears with:
a. DC 490/480/470/460 or WCP 65/75/90: [Print Call for Service Report].
b. DC 555/545/535, WC M35/M45/M55, or WCP 35/45/55: [Print Call for Assistance
Report]
4. Press [Print Call for Service Report] or [Print Call for Assistance Report].The report
prints within 30 seconds.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Aug 24, 2011
Error code 010 398
The only suggestion I have would be to reboot the machine and try again. In a lot of cases any error codes AKA Fault Codes begining with 010- point to a major mechanical error.
Nothing specific sayiing so in my research, if a reboot doesn't bring the machine back up your next step would be to contact your Xerox service technician to go onsite to resolve.
If you're not holding a maintenance agreement on the WCP device
Check with the person you bought the device from to see if there is anything they can do to assist.
The WCP device you have is an older model and if you are experiencing problems with it on a regular bases you may want to contact Xerox and see if there is a possible upgrade strategy they can assist with and get you into a newer model with out breaking the bank so to speak. ????
I hope this helps.
Mar 10, 2015 | Xerox WorkCentre Pro 123/128 Printer
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Workcentre Pro 2636 giving error message of: Clear Jam in area 1. we have done this with no luck. Have opened and cleared all areas, even shut the machine down and started back up with no luck. Any...
From past experience this is more often than not caused by a little tiny piece of ripped paper still stuck in the machine somewhere. Turn all rollers and have a really thorough check, especially inbetween the rollers and under any clip down areas on the rollers too..
Jan 27, 2011 | Xerox WorkCentre Pro C2636 Color Copier
Need to remove the finisher from a xerox 2636
Aug 19, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Oce vs. Xerox Recommendation
I can't speak for the OCE model, but I have worked on the WCP 7345 (I'm a trained Xerox tech), and I find them to be very reliable when it comes to recommended repair cycles and overall wear-and-tear of consumable parts.
Aug 21, 2009 | OCE Office Equipment & Supplies
My plain paper will not feed to print incoming fax????
If it is a WCP 580. clean the feed tire very well with something like formula 4009 then rinse it with alcohol.
Most likely that feed roller is cracked and worn. Will need replaced.
Jul 01, 2009 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Greek language
I am not 100 percent sure if you just want a Greek driver or do you want to change the screen language to Greek. I can tell you how to do either if you specify which you want.
Jun 05, 2008 | Xerox DocuColor 1632 Laser Printer
Xerox WorkCentre Pro C2636 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
