Question about Tricity Bendix Washing Machines
Hi I have a Tricity Bendix WDR1041W. It has stopped mid cycle and clothes are now stuck in washing mashine. It is also full of water and comin up with e20. The problem is the door wont open whilst it is full of water and also wont open midcycle. None of the programs work on it at all. Please help!!!! Thankyou!
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
  • 135 Answers
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
Posted on Feb 24, 2009
  • 272 Answers
SOURCE: dear ladies and gentlemen,
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
Posted on May 16, 2009
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Jan 14, 2014 | Tricity Bendix TM310W Electric Dryer
Tricity aw 1000 front loader washing stuck in will not open
Does the y splitter have little valves on it? Make sure both are open.
Nov 28, 2013 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Problems after getting fluff in machine
Behind the little door is the filter which will be full of this stuff.
Just unscrew and take it out to clean.
Thankyou for using Fixya.
Jan 22, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
