Question about Kenmore Elite 45986 Front Load Washer
Lights on Front Panel Flashing
I have a Kenmore Elite HE 3t. The other day I was washing and it stopped in the middle of the wash. All of the lights on the front panel were flashing. I unplugged it for about 10 minutes assuming that it would reset itself, but it didn't. I had a SEARS technician come out and he told me that it was the main board. Well, I had the main board replaced today, and that was not the problem. Mind you this is the 3rd person in two weeks to look at my washer. This last guy is thinking that is could be the front panel that has gone out. PLEASE HELP!!!!!
  • Toby Norton
    Toby Norton May 11, 2010
    Is it flashing an error code or are all of the lights flashing? If ALL of the lights are flashing and the main board has been replaced, the it probably is the display board. If sears has repaired it and not corrected the problem, they have a 90 warranty on the work they do.
  • 246 Answers
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Posted on Jun 13, 2008
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
It wont drain and wont spin. It is flashing F and DL. I have a Kenmore Elite HE 3t
Hi, most common problem is the pump gets plugged. Take off the loser front panel and you can see the pump front middle. It has an access that you can unscrew and see what is in it. You can get the water out of the machine by using a shop vac and **** the water out of the drain hose. This will let you get all the water out. If you have a floor drain, you can lay the drain hose in it to release MOST not ALL of the water.
If I can assist you fyrther, please let me know.
THanks
Vic
May 15, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
F and then 06 error/ Kenmore elite HE 3T series 4
well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
When washing, it stops and says F11. What does that mean?
F-11=Serial Communication Error
Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
(MCU) cannot be sent correctly.
PotentialCauses
. CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
Unit (CCU)
. Checkt he Drives ysteml or anyw orno r failedc omponents
. ReplaceM CU
. ReplaceC CU
. Replace Motor
. ReplaceW ireH arnes
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 42922 HE 3t
sojds as if theresnot addeguate wate rsupply going to unit make sure
both hot and cold water is supplied and working to the unit
Apr 02, 2008 | Kenmore 46462 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Robert Rankin
