Question about Toshiba e-Studio 350 Copier
I have problem , My machine is toshiba 350 and proble is C970
  • 29 Answers
It has a problem with the HIGH VOLTS CARD, maybe in the transfer area.
other posible solution it is that in the charge unit need to clean by humid.
Posted on Dec 03, 2010
Call for service c970
C970 Description Process related service call
High-voltage transformer abnormality: Leakage of the main charger is detected.
Jan 12, 2015 | Toshiba e-STUDIO280 All-In-One Laser...
Error c970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
ERROR C970 TOSHIBA E STUDIO 350
[C970] High-voltage transformer abnormality
(1) Is the main charger installed securely?
(2) Check if the spring of high-voltage supply contact point is deformed.
(3) Check if the charger wire is broken or the main charger grid is deformed.
(4) Check if any foreign matters are on the charger wire or main charger grid.
(5) Is the transfer/separation charger installed securely?
(6) Check if the transfer/separation charger wire is broken or unhooked.
(7) Check if any foreign matter is on the transfer/separation charger wire.
Oct 02, 2012 | Brother HL4040CN Laser Printer
My problem toshiba e-s352 Code C970 and print is not ok please sole
C970 is an arc check your bios pin on maincharge as well as the transfer seperation unit its loosing powerto one of the charges
Aug 17, 2011 | Toshiba e-Studio 350 Copier
Problem on 350 as C970 Help me
you have to clean the main charge area because the corona have humidity and dust.
Nov 04, 2010 | Toshiba e-Studio 350 Copier
How can i fix the error code C970 on my toshiba e-studio 230?
Nov 01, 2010 | Toshiba e-Studio 350 Copier
Toshiba e studio 350 has a c970 code
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
May 22, 2009 | Toshiba e-Studio 350 Copier
I have proble with my toshiba estudio166 it is not printing
Ok, if the copier is connected to your pc through usb port, then your pc suppose can print to the copier. Run a test print. If cannot, then u need to check the usb cable, usb port.
* Assume that the driver is ok.
Feb 25, 2009 | Toshiba e-Studio 350 Copier
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
Toshibae-studio232 code C970
Hello sir; C970 means high voltage board open , it need to repaire or replace.
Toshiba e-Studio 350 Copier Logo
118 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Marius Chiriac
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
