Question about Motorola Mobility RAZR V3m Cellular Phone
Lcd screens both front and main screens go blank occasionally then they will work again for a few times? is there a way to clean the connections or something?
The best way is consult your phone at any repair shop.im sure it needs to be clean off..
Posted on Jun 14, 2008
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
My monitor occasionally blacks out. I turn just the monitor on -- wait a few minutes then it works ok for a while until it blacks out again
There are controls that turn off the monitor, both in Windows control panel and the monitor itself. The system should know if activity is happening, and should not blank if active.
Look at screen savers, too.
Jan 28, 2011 | HP w1907 LCD Monitor
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Laptop screen notworking
My laptop screen goes blank from time to time and these are the reasons it happens. If you boot the computer with the screen open while on battery sometimes the screen doesn't connect properly, but closing and re-opening the screen fixes this. Also, if your computer has a video out connection such as HDMI or S-Video look at the F5 key and see if it looks like it might mention switching screens at all. If it looks like it does, hold the fuction (FN) key and press F5, give it 10 or so seconds, if that doesn't work, try it again a few times, waiting each time. If none of this gets your screen back, it is a hardware issue not a settings or user issue.
Jan 14, 2009 | Zenith L13V36 13" Flat Panel LCD Monitor
Lg shine blank lcd on replaced lcd
u r having a problem with flex cable part connects lcd to keypad/numbers.
its very sensitive part.
try replace it but try to be a lil bit carrefull at this time.
Jan 09, 2009 | LG Shine CU720 Cellular Phone
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Broken phone
Hi all,
I had simmilar problems ie screen ok when closed but fuzzy when slid open, screen going blank etc.
I replaced the flex cable that connects the screen to the main board and the phone now works perfectly.
Nick
Jul 17, 2008 | Samsung SGH-U600
Motorola Mobility RAZR V3m Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
