Linsksys wireless, when pluged in the power light does not light but the 4 internet lights do light. The computer says signal too low.
  • siobhan1 Jun 13, 2008
    Thanks. Checked with multimeter and power ok, but not sure how to check the connection.
  • 203 Answers
I would try to swap the power connector and check the voltage output with a multimeter from the POwer Outlet. It very well may be that the power connector for the Linksys may be defective and putting out a weak output and therefore causing your linksys unit to receive poor signal.
Posted on Jun 13, 2008
  • Alex
    Alex Jun 14, 2008
    Put the positive terminal on the inside of the connector of the power jack and the negative terminal on the outer shield of the power jack connector, not in the outlet on the connector that plugs in the Linksys but before doing that plug the power supply to the outlet on the wall and test the connecting lead that goes into the linksys power input , see how much power is coming out of the lead. And im sure if all else fails just exchange the unit for another one.
    Good luck.
Low connectivity for d link 524 airplus g
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
May 25, 2012 | D-Link AirPlus G DI-524 Wireless Router -...
I have a deslk top with cogeco no router, got wireless laptop, used linsksys router befsr41 ver2 no disk how to hook it up so i can use the laptop thank you
This router WILL NOT broadcast a wireless signal. In order to use it you must connect a cable to the laptop just like you connected the desktop to the router.
Jul 28, 2011 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless-g 2.4 GHz The power light, the number light (which spot the cord is pluged into) and the internet light are all blinking. I can no longer access my wifi from other devices in the home It...
check in your router if it has the mac address resctriction to filter which pcs or lpas can connect to the net and disabled or add the pcs required
looks the wireless mac filter configuration y the web admin page
Mar 22, 2011 | Linksys Wireless-G Broadband Router
Device turns on but will not move the mouse
Observe to ascertain that is a wireless optic. usually wireless optic mouses require the adaptor section of be pluged to the computer to capture the signals. Also, mouse should light up soon after batteries were inserted in compartment. Power off the computer completely, repower on should capture the new settings.
Feb 06, 2011 | Kensington PocketMouse 72214
WLAN light will not go on
I would advice you to perform a factory reset on your unit if you think the wireless light is completely and your wireless computers are not connecting wirelessly. Factory reset will delete all your settings and you need to set up the internet back.
You can also try power cycling the unit. Turn if off for 2mins and then power it on , then observe the wireless light.
There is also a possibly that the wireless light is just dim. You can check your wireless computer if they are getting a signal from your router. If they are getting a signal, that means the wireless light is not properly light up.
Please give me an update to your concern. So i further assists you
Jul 04, 2010 | CP International WBR-6000 Wireless Router
try unplugging all the wires from your router including power then after 5mins plug internet cable in to the router then plug the power cable into the router then leave it for a few mins untill the router has conected to the internet (usualy indicated by 2 lights changing from flashic which is connecting to solid which is connected then plug the rest of the wires in with the router still on and try it then
Sep 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router works then knocks main computer off
internet service went dead and service was restored
Sep 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
