Question about Roper Washing Machines
Washing machine power cord is broken - Roper Washing Machines
  • 246 Answers
If the cord is dammaged and needs replaced, vist your local appliance parts store or check the manufactures web site for a replacement one. Once you have one, open the console and unplug the old cord. The replacement part should have instructions for a step by step.
Posted on Jun 13, 2008
I have an LGwd8050f washing machine.A broken tree fell on the power line outside my house blowing our power along with a few appliances, namely the washing machine .does IT HAVE A FUSE
no it does not have a fuse you can change some do have a power filter that may have gone bad under the top panel unpug the unit take the top off and follow the power cord to the filter if it has one it is the first thing the cord will connect to. after that it would be the computers are toast.
Nov 02, 2016 | LG Washing Machines
My washer wont start
Hi Kimberly:
That's not much info to go on so I'll try some basic starting points.
- Is it plugged in?
- Is there power in that receptacle? Check by seeing if a hair dryer or other appliance will run when plugged in there.
- Is the circuit breaker tripped?
- Did it work before, and what happened when it decided to not work?
- Could the supply cord be broken? This can happen on older machines and usually occurs from where the cord goes into the machine to where it is connected to the machines internal electrical system.
Hope this helps you to isolate the problem.
SAFETY TIP - Do not start checking for a broken supply cord unless the machine is unplugged.
Mar 11, 2015 | Washing Machines
Why doesn't my washing machine start
turn it on - no seriously - abit more information please?
Fuse
wire broken in power cord
does it light up
is the door shut
Jun 16, 2014 | Maytag Washing Machines
My lg front loader washing machine would not start at all ! it seems like there's no power at all ! what should i do ?
check power at wall outlet us lamp to test for power
check power cord look for broken or loose finger in plug
Jun 09, 2011 | LG Washing Machines
My bosch maxx laundry machine wont turn on
If you dont have power to the machine, your electric cord from machine to power point is broken. To check this turn on at power point and at machine hold cord in hand and shake if machine makes any noise you have a broken lead which can be cut at break and fixed,but better replacing with new cord Hope this helps
May 25, 2010 | Washing Machines
The machine will not turn on
check your wall recept with a volt meter and make sure you dont have a tripped breaker... then inspect the power cord make sure its not broken.. if all that checks out than replace the timer
Jan 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
J845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 11, 2009 | Samsung Washing Machines
Asko 12505 washer no power replaced fuses still no power door will not open just nothing
Can you access where the power cord goes into it? If so measure voltage at any /all connections. Also look for anything obvious, wires broken, disconnected, burned etc. Hope it's an easy fix.
Mar 31, 2009 | Washing Machines
Washer won't start
Check for power at the terminals and the plug. If the plug and or terminals are discolored, broken, and you have no continuity-replace the power cord, or terminals or both. After a power surge, or lighting these could become burn or broken, and therefore power could be lose.
Mar 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
253 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
