Question about Lexmark T630 Laser Printer
202 pam jam
We have followed instructions. paper is completly cleared but "202 paper jam open rear door" will NOT clear. turned printer off several times. no luck. please advise. thanks
  • Anonymous Nov 04, 2008
    202 paper jam open rear door, but there is no paper in printer
    Problem Solver:
  • 4 Answers
Usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
One of the 2 sensors on the fuser will be stuck open, which means someone has pulled the jammed paper through knocking the spring off the sensor.
Check to see which sensor is not spring loaded then unscrew it replace the spring and you should be up and running!
Posted on Sep 11, 2012
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Carriage jam message...........comes on no matter what.........reset several times
Solution one: Turn the All-in-One off and on again Turning the product off and then on again might resolve the issue. Step one: Turn the All-in-One off and on again
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product
Step two: Print a self-test report
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01461502.gif ). The Setup menu opens.
  3. Press the arrow button to select Tools , and then press OK .
  4. Press the arrow button to select Self-Test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any jammed paper Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Use the following steps to check for and remove jammed paper from the rear of the HP product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product.
  4. Squeeze the tab on the rear access door to release it, and then pull the door outward to remove it from the product Figure 1: Open the rear access door
  5. Gently remove any jammed paper from the rollers inside the product. CAUTION: If the paper tears while removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Jun 21, 2011 | HP Photosmart C5280 Printer
202 PAPER JAM OPEN REAR DOOR, CLEARED THE PAPER BUT STILL GETTING THIS MESSAGE
Turn off and back on. If the error is still there, look in different areas of the printer, somewhere there is a piece of paper stuck. Sometimes when clearing a jam, little pieces will get stuck in the rollers and you just need to search for them and remove them to clear the sensors.
Mar 16, 2011 | Lexmark Office Equipment & Supplies
PRINTER INDICATES NO PAPER
Dear Sir,,
plz folow this step,
Follow these steps in the order presented to resolve the issue. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One CAUTION: Do not try to clear a paper jam from the front of the product, which can damage the print mechanism.
  1. Press the Power button ( spacer.gif c016022020.gif spacer.gif spacer.gif View Full Image spacer.gif) to turn off the product.
  2. Turn the product to access its rear side.
  3. Press in the tab on the left side of the rear access door to release it, and then pull the rear access door out to remove it. Figure 2: Remove the rear access door spacer.gif c01422030.gif spacer.gif spacer.gif View Full Image spacer.gif
  4. Gently remove any jammed paper from the rollers.
  5. Replace the rear access door, with the right side inserted first.
  6. Gently push the door forward until it snaps into place. Figure 3: Replace the rear access door spacer.gif c01422031.gif spacer.gif spacer.gif View Full Image spacer.gif
  7. Open the front access door, and then remove any torn pieces of paper from the opening. Figure 4: Open the front access door spacer.gif c01669517.gif spacer.gif spacer.gif View Full Image spacer.gif
  8. Press the Power button ( spacer.gif c016022020.gif spacer.gif spacer.gif View Full Image spacer.gif) to turn on the product, and then try printing again.
Read more: http://www.justanswer.com/questions/2ya2z-i-had-a-paper-jam-and-had-to-disconnect-my-printer-and-since#ixzz0kTjAnpnQ
Thanks For Your TIme,
Apr 08, 2010 | HP PSC 1510 All-In-One InkJet Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Apr 13, 2009 | Dell Office Equipment & Supplies
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
Lexmark T630 Laser Printer Logo
8,784 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
