Question about Memorex Audio Players & Recorders
It turns on goes to the first song then cutts off
  • 8,596 Answers
I would need the exact model # to be of more help, but there are several possibilities. I would start with a simple reset: the method will be listed in your product manual which is also available on the web at:
http://www.memorexelectronics.com/html/manuals.php
If reset fails to resolve, you have a corrupt db. To fix this, I would look for a firmware upgrade on Memorex's website first. If they don't have one for your model #, then reformat the player.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jun 14, 2008
Zebra label printer cutt off prints
In printer control panel menu check the print width of the label according to the size mean to say if you have 4 inch label the print width set to maximum value if print width set minimum then cutts off the print.
Codabar Pvt Limited Pakistan
Apr 13, 2014 | Zebra TLP 2824 Printer
Every time we insert paper, even one sheet, it goes to overload. We cleaned out all paper from inside and its still doing it.
Have you ever oiled the machine...its a cross cut shredder and you are supposed to regularly lubricate the cuttting shafts with shredder oil.
Feb 08, 2011 | Royal VF1012mx Shredder
Jerks at 4000 rpm won't accelerate past 4000
it cutts off the fuel after 4000 rmp check the cutt off switch
Aug 01, 2010 | 2000 Mazda Protege
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
PS3 not turn on anymore
HI, this is the result of a weak and, failing power supply unit. you will need to contact Sony for a power supply unit replacement procedure.
To clarify. Your power unit has failed.
Overheating is a big cause of power unit failure. To prevent this in the future. i recommend purchasing a aftermarket cooling device.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
99 intrepid hard to start and or cutts out, what is my solution
n most 90's and up Dodge/Chrysler vehicles, you can try to pull codes from the car's computer as long as you still have a charged battery. Put your key in the ignition, and turn it forward, but not far enough to engage the starter. Turn the key back to the Off position, then forward, back and forward again. In early 90s vehicles, the Check Engine light is going to flash a number of times. Often, code 55 means it is completed.
In mid and late 90s vehicles, you will often get a 4 digit code that may help you diagnose problems starting, mostly checking the eletrical, ignition and sensor systems.
Jul 03, 2009 | 1999 Dodge Intrepid
Cutte Sonnu
what is your problem Cutte ?
Apr 06, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
60 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
