Question about Epson Stylus CX6400 All-In-One InkJet Printer
WHEN PRINTING PHOTOS LINES APPEAR
PRINTING A4 PHOTOS LINES APEAR WHEN FINNISHED
  • lropac Oct 05, 2008
    When I print out a picture there are blank line every inch or so throughout the printout.
  • ReenyNY Nov 15, 2008
    Aarrrgh!  Vertical lines print on my photos!!  Brand new HP CC558!  Using HP photo paper, best quality print, etc. ?????????? @&#(! ????????
    Scholar:
  • 94 Answers
Hi, It is unfortunate that you are having this difficulty with your printer. One of the best solution that we can give to you is run a series of head cleaning. Please try the following steps below to clean the print head in most effective way:
1) Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink, your printer will require service.
Tirzo
Posted on Jun 16, 2008
CanonMG5150 printerwill not print to the bottom of the pagee page
In printing preferences for the Canon Driver make sure it is set to A4 and not 8.5 X 11
Mar 23, 2014 | Canon MG5150 AllInOne Printer
My MX860 prints photos with lines through it. How do I fix this?
Hello. Remove the cartridges and follow the instructions in the link below. if this does not resolve the issue the cartridge may be starting to run dry and a replacement may be needed.
The link is http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helpsRegardsGrant
Nov 06, 2011 | Office Equipment & Supplies
When printing photos especially A4 size my printer leaves white dotted lines across the photo
This is caused by the paper feed wheels (small spiked metal wheels to draw the paper through the printer.) Unfortunately, there is no way I know of to fix this, but you could try using different types of photo paper.
Aug 15, 2010 | Epson Stylus Photo R300 InkJet Printer
Photos are not clear and has lines
I have the same problem with my camera. Olympus tech says the lens needs to be replaced at $185+ and it's 18 months old with little use. Not happy, not worth it. Don't buy this camera.
Dec 18, 2009 | Olympus FE-340 Digital Camera
When printing photos, black lines appear.
Have you tried cleaning the heads? it should tell you how to in the manual.
Aug 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
When printing photos, several horizontal lines lines appear. How can I remove/prevent them?
It must the nozzle check is not perfect. Check nozzle and do head cleaning procedure. If there is just little nozzle clog ( 1 - 2 lines missing), you can get good result with best photo/photo rpm setting.
Jul 23, 2009 | Epson Stylus R380 InkJet Photo Printer
Dark vertical lines on printed photos 18cm apart
Remove the cartridge and put it back in. If same issue persists, try to do head cleaning and nozzle checks simultaneously from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on those patterns appears, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal lines
do a nozzle check, or printer utility check on the printer and see if this helps.
Jun 08, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
