Question about Pentax Optio M40 Digital Camera
My pentax camera will turn off and the lens will not close tightly
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 04, 2010
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
Vivitar lens to Pentax K-x camera adapter.
It depends which camera they were originally designed for use upon. If they are M42 lenses, then yes, but without any automatic facilities whatsoever - if not, then it is unlikely.
If you sign on to this link as a guest, you may find answers there. Pentax Forums The Ultimate Resource for Everything Pentax
May 29, 2017 | Kodak LENS ADAPTER 49 TO 55MM Lens...
Lens will not close any fixes?? May have sand in lens
First make sure your batteries are fresh then turn the camera on. With the lens extended and pointing towards the floor turn off the power while gently tapping each side of the extended lens tube.
You may have to do this several times to dislodge the foreign matter jamming the lens tube mechanism. Do NOT force it at any time. If this doesn't work let a Camera tech handle it for you.
Mar 12, 2010 | Pentax Optio S10 Digital Camera
Pentax camera optio a10 won't retract
It sounds like you may have a bad lens assembly, or a bad main board. If it is sticking, it will buzz. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Jun 19, 2009 | Pentax Optio A30 Digital Camera
Pentax Optio A10 Camera Lens won't retract
It sounds like you may have a bad lens assembly. If it is sticking open or closed, it will usually make a buzzing noise. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Mar 27, 2009 | Pentax Optio A30 Digital Camera
Nikon to PK conversion
Copy and paste this in google, it may help.
nikon to pentax lens converter
Mar 12, 2008 | Cameras
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
Pentax Optio M40 Digital Camera Logo
102 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
