Question about Garden
I have a ryobi rcs4040ca 40cc 16bar petrol chain saw.the spindle which the starter rope is attached to has broken from the housing and the recoil spring has uncoiled itself.any suggestions
  • 7,733 Answers
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks!
Posted on Nov 04, 2010
How do you replace starter spring on mcculloch 1.2 chain saw
If yours is not repairable, you can buy the whole starter housing , or just the starter parts to repair your starter assembly. The actual spring can be mounted on the starter spindle, and using strong clips, can be held in place or using vice grips to hold in place once the spring is tensioned , and in place. Then match the starter spindle over the spring. Next the starter rope, will have to rewind completely once it is installed back on the saw. If not, you can tension the spring by holding the rope at the starter spindle, and twist the starter spring about 4 to 5 complete revolutions clockwise, and then winding the rope on by releasing the spring . You can find videos on youtube and other online video services, to get a visual of what I described.
Jul 20, 2015 | McCulloch Garden
Parts diagrams
We call that a duck bill vavle. You may have to buy fuel cap for it. The Home Depot should be able to help you with that. Or you can call Ryobi, I think they will sell you one direct
Sep 02, 2014 | Ryobi RCS4040CA 40cc Petrol Chainsaw...
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
I replaced start string and have no recoil of it on a Ryobi 30 cc
Watch the video, about 60 seconds in he explains how to tesion it.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chain saw, pull cord won't turn rotar assembly
I had the same problem with my 18 inch Ryobi saw. The problem is the tabs that engage the recoil to the flywheel are of poor quality steel and they bend out of position. The end result is when you pull tyhe rope it just jumps and wont start. Eaven the new parts do the same thing. Simple soultion is remove the recoil starter four screws require a torx bit or a flat screwdriver. after your remove the recoil starter using a pair of pliers bend the two tabs upwards untill they are not quite straight up (about a 80 degree angle be carefull not ot brake the tab off) once you have done this remove the center nut that holds the flywheel on. the silver pins that hold the tabs in position need to be punched out but remember how they go back by doing only one at a time and remember how the spring is installed. Turn the flywheel over and using a punch and hammer remove the pins. Put the tabs in a vise to hold them sucerly clean the steel as best you can on the inside of the bend. Fill the bend with brazing rod or coat hanger if you haven't got any brazing rod avilable. You don't have to com;leatly fill the bend but put enough in there to suport the tabas so they can't bend agin. Reassemble the saw and you're done. Mine works great now, better than new. This problem isn't limited to recon saws only, mine is a new saw and I still had the problem. Good luck herbdogs
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
217 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
