Question about Durabrand STS92 System
End of the speaker wire
No im talking bout the end of the speker wire that connects to the dvd player the colored end of the speaker i want to know if thats replaceable???
  • 4,472 Answers
I dont understand what you mean by what you said. What is the color of the end? What is it the end to? the end of a wire?
I think I might know what your talking about but I want to make sure we get it right the first time.
Thanks,
Lee
Posted on Jun 13, 2008
Wiring after market spekers need to know if a or b is positive or negitive
dont know about a or b but wiring should be color coded. these should be the colors and description for 02 silverado
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 31, 2011 | 2002 Chevrolet Silverado 1500
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Correct placing of leads from dvd player into back of TV?
If you are using RCA jacks to connect from the DVD player to the Television (RCA jacks are the connectors that have a white & red colored end for right and left speaker sound and another yellow end for video) connect one end to the back of the DVD player where it says "out going connections" and the other end to the television in the "incoming" connections. Remove your television antenna from the tv to the DVD player. The antenna signal goes to the DVD player and the Dvd player sends the picture outgoing to your tv set.
I hope this helps?
Sep 12, 2011 | Panasonic Televison & Video
Were can I get the output to input cable from dvd to the speker sc36ht
the audio output of your DVD had to be connected to the audio input of your amplifier for the speaker to work
Jun 09, 2010 | Supersonic Progressive Scan DVD Player
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Need factory stereo color codes
best way is to get in the with a multireader and find a constant power and a ignition, for the speakers, i use a AA battery with a wire on each end, to test the spekers, you will hear a pop from speaker, so you can find which wires go to what speaker.
May 05, 2009 | Car Audio & Video
Need to know the speaker wire code for a deh-425 pioneer car stereo
what code you talking bout, like which color goes to what... i need more info...
Aug 12, 2008 | Car Audio & Video
Connecting Creative t6060 to my philips 5.1 dvd player
Hi Guys,
I am teh person who started this thread and I am happy to find the solution. The problem is not with Speaker but it is with DVD player. Infact it is not a problem, it is the setting which needs to be changed.
Go to the Setup menu and change the Speaker settings and set it to MultiChannel. This will give you sound to rear and center whenever it has to.
Hope this helps as it has to me.
Feb 25, 2008 | Audio Players & Recorders
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Durabrand STS92 System Logo
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
