Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave working but wont heat up - GE Spacemaker JVM1640SJ Microwave Oven
    Brigadier General:
  • 8,909 Answers
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Nov 04, 2010
Why wont my microwave heat when everthing else works?
The unit is not producing microwaves, therefore replace it.
May 03, 2014 | Rival RGST902 - 0.9-cu ft Microwave Oven,...
Microwave oven wont heat
If the microwave oven is 7 years old or less the most likely problem is the magnetron, or the inverter board, cost consideration should be carefully thought out.
Jul 19, 2012 | Jenn-Air Microwave Ovens
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
Sep 27, 2009 | Whirlpool MH7140XF Microwave Oven
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Microwave wont heat up
did it work later???if so the thermal cutout was hot and needed to reset otherwise it could be the fuse,h.v. diode,h.v. capacitor,or the magnetron,the first three are cheap, the mag is not,let me know
Jul 19, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave wont heat
Check out the door switch. Could be malfunctioning.
Jul 10, 2009 | Maytag MMC5000 Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
