Question about Toshiba E-STUDIO 450 Copier
C010 - Toshiba E-STUDIO 450 Copier
Copie noir en multi copie dans un copieur e studio 450 de toshiba
Posted on Jul 20, 2011
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Kelly
Posted on Nov 04, 2010
  • penis4545521 Feb 12, 2011
    There are no belts in the main drive or feed drive of the e-Studio 350/450
ERROR CODE C010 OF TOSHIBA ESTUDIO230
Main motor is not rotating normally. May need to check and clean the belt drive system.
Jul 13, 2016 | Toshiba Office Equipment & Supplies
Copiers
Not sure what you are looking for here. You are correct c010 is error code for main motor drive. You might check to make sure everything is able to move freely in the paper path. Check for paperclips, staples, crumpled paper anything that would hinder the movement of the components connected to the drive motor. If everything checks out and you can verify the motor is getting power then you are likely looking a replacing either the drive motor itself or the electronics that drives the motor. It may be prudent to have a qualified service person look at it before you spring for the board or motor though. Good luck have a fabulous day.
Dec 06, 2012 | Toshiba e-Studio 350 Copier
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
Call for service c010 how to solve it?
C010 indicates main motor problem...
U need to open up the back cover, perform output test to check whether the main motor is working. 03-101(ON)/151(OFF)
Dec 23, 2011 | Toshiba e-Studio 232 Black and White...
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Sep 30, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-St 350 - C010
"Main motor not rotating normally"
Check to see there are no binds in the drive system...other than that... motor may be bad.
Nov 06, 2009 | Toshiba e-Studio 350 Copier
Forgot password toshiba estudio 450
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Oct 23, 2009 | Toshiba Estudio 200L Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
424 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
