Question about HP DesignJet 5000 Printer
Hi, I am very new to this but i currently have a designjet 5000 and after printing at any given time the image would turn black or just stop. now it says replace all printheads could that be right that they all need replacing? I am totally stuck and dont have the money for someone to have a look at it. Is there anything i can do to find the problem thanks
  • HP Master
  • 7,733 Answers
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Posted on Nov 04, 2010
Print images overlapped
Your belt is either perished (look for bits lying below or on the print) Secondaly your carrage bar needs a bit of lubrication. Use a couple of drops of sewing machine oil and coat the entire bar with a THIN coating of oil. Do not smear oli all over the place, just lightly on the bar.
Aug 24, 2011 | HP DesignJet 5000 Printer
I have a HP designjet z2100 printer but It stop printing larger banners and now will print banners in a tile format not one contiuos document
Hello.
If the problem occurs from one computer only, remove printer from Printers and Faxes and renistall the driver.
If needed, here's the link for the driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=pl-89035-1&jumpid=reg_R1002_USEN
If the problem occurs from more than one computer, please let me know.
Hope this helps.
Jul 19, 2011 | HP DesignJet 5000 Printer
HP Designjet 5000 Error..
Some time it depends on what you are trying to print. If this is a receipt or something off thre internet, try to copy the page and pate it on a blenk microsoft office page, it this work try to print, if it works, the email is corrupted.
Feb 07, 2011 | HP DesignJet 5000 Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
Error code 96:11
Due to its special nature, the scratch pool should not be directly targeted by any policy. Ensure that all policies and schedules specify a volume pool other than the scratch pool; then run the job again.
May 27, 2009 | Designjet Black Designjet 30/130 Series...
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
HP DesignJet 500PS mixed ink color in tubing
Hi
Think this should be fairly easy. If it's still printing quite happily but just th colours are off, probably means your print heads are fine. Hold onto the new ones and return to store for credit.
All you cand do to flush out the system is to keep printing. Belt out a couple of phots and it should start to come good maybe 1-2 photos maybe 5-6. But should come good.
Regards
P.S.: refer to manual that you do now have all the rite tanks in the rite place.
Dec 29, 2008 | HP DesignJet 5000 Printer
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Not printing black dark enough, faded
Get a manual off the internet -- they are avalible for free for now as hp has stopped supporting these plotters. Then llokup the section on adjusting the ploter carraige head.
Techs adjust the head by turing the mentioned screw a little ie from 12 oclock to 1 oclock to the right test for print quality then adjust back or more .
hope that helps
Aug 02, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 5000 Printer Logo
283 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
