Question about Sony VAIO V505 Notebook
I have a sony vaio v505bx when i pres the power butten the boot led and the power led flash once then nothing. When i plug the ac adapter in the power led flashes like it is charging the battery but thats it. i now is a bit vague but can any body help?!
  • 93 Answers
I had same problem with my HP dv9922us. it is ether the power switch or the motherboard overheated and cooked. wish i had better news but there are not much to laptops.
Posted on Nov 04, 2010
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
Loose dc connector Sony VAIO
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | Sony VAIO Computers & Internet
Plugged it in and there is power going to the computer (orange batter light is flashing) but the green power button is not lit and the computer is not booting up. I should not need the battery if plugged...
You're correct. The laptop should power up when connected with AC adapter with or without the battery being installed. If you still have no power, the power supply on the laptop may be bad.
Feb 20, 2011 | Sony Vaio PCG FXA36 Laptop Universal AC...
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
VAIO PCG-8Y2L won't boot - no display, no nothing....
I smell a Hardware fault,or your Display might be busted...I suggest you Visit a PC store and let them check it out.
Oct 30, 2009 | Sony VAIO Notebook
Sony Vaio PCG 7v2l won't turn on
this may or may not be the solution but its some sort of indication of what is going on. Ok when you plug the ac adapter do u get a flashing light to indicate your batter is being charged? If you do then there is power going through the laptop to the battery, which is great. Now if you don't have the indicator flashing then it could be that the where the AC adapter plugs to the laptop could be now faulty. The other one could be that the AC adapter plug i.e. head that goes into the laptop some how internally has a severed connection.
comment on what you find and ill see what else i can advice :)
Plz rate me
Jun 02, 2009 | Sony VAIO FRV Notebook
Sony VAIO PCG-V505BX Battery life
That is not normal definitely your battery has some problem and needs a replacement because a normal working battery should last for about 2 hours or more..
Hope that helps........
Sep 07, 2008 | Sony VAIO V505BX Notebook
Sony VAIO V505 Notebook Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
