Question about BenQ FP767 17" LCD Monitor
How to get audio from a benq fp767 lcd monitor
How do i get audio from my benq fp767 lcd monitor
  • Anonymous Mar 17, 2014
    can you connect a fp767 monitor to a macbook pro?
    Guru:
  • 1,342 Answers
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Posted on Jun 13, 2008
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
The color on my beige BENQ FP767 is blue i cannot fix the color schematics back to the default settings, please help
Blue cast on the screen? Then check all the pins on both ends of the video cable, try it on another PC to make sure it is not video card problems.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 22, 2010 | BenQ FP767 17" LCD Monitor
When I switch on my FP767 monitor the light appears as blue, but nothing on the screen.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL (BenQ makes Dell MONITORS) monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 21, 2010 | BenQ FP767 17" LCD Monitor
FP767-v2 - 17" LCD Monitor: when you turn it on benq flashes on the screen...
Check the cable on your monitor through video card if there is loose connection. Check also the video card by replacing it with your extra video card if you have. I think the problem is not the monitor but the video card.
May 18, 2010 | BenQ FP767-v2 - 17" LCD Monitor
How do you remove the stand from a BenQ 767?
remove screws either side where stand go into back of monitor.
then slide stand toward bottom of monitor and it should slide out
Jan 14, 2010 | BenQ FP767 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem
IT seems you are not technically trained in electronics.In this case it's difficult to explain via this board,Best you find someone to fix it for you,you can try contacting Benq Support locally.
Sorry for not being able to help.
Samir
Jun 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Logo
316 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
