Question about Microsoft Windows Live Messanger
Hello I am getting the problem with sign in to MSN messenger, Error 80048820 I have checked / tried all the steps described on here: http://windowslivehelp.com/solution.aspx?solutionid=5f26a9b4-1c1a-4d0b-a55b-fafabe2f05e7 Issue has not resolved Thank you in anticipation KR Maria
Weak
Posted on Dec 23, 2010
  • 1,719 Answers
It could be fairewall or antivirus (AVG is known for this issue). Remove Instant Messaging (MSN) from firewall.
-open AVG Antivirus
-Click on "Web Shield"
-Click on "Instant Messaging" tab
-Uncheck "MSN protection" box
-Click Save Changes"
Posted on Nov 04, 2010
    Sergeant:
  • 158 Answers
However, here are some suggestions you should check/try if you haven't already.
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password @ https://login.passport.com/ChangePW.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
and do the same for the following:
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 MSXML3.dll
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
Msn messenger wont let me sign in error code 80048820
you will have to check your email and password if its not that unistall the program and reinstall, the problem should be fixed by then
Jan 30, 2010 | Dell Inspiron 1525 Laptop
Anybody can help me with this? When i try
Solutions to MSN Error Code 81000306 1) Wait for MSN to repair their Server! Meanwhile check the status of the Messenger service, at: http://messenger.msn.com/Status.aspx
2) Delete ListCache.dat
Launch CMD and navigate to %appdata%\microsoft.
CD %appdata%\microsoft
Dir /s ListCache.dat
Decide if you want to delete the cache.
Del /s ListCache.dat
Restart your MSN Messenger.
3) Register softpub.dll.
It would do no harm to also use regsvr32 to re-register: wintrust.dll, initpki.dll, Rsaenh.dll Mssip32.dll and Cryptdlg.dll. Here is the command string to register these dlls. Launch the 'Run' command and paste:
regsvr32 softpub.dll Wintrust.dll Initpki.dll Rsaenh.dll Mssip32.dll Cryptdlg.dll
4) Another problem could be firewall related, thus try temporarily disabling the firewall. If this cures the problem, make sure that MSN Messenger is allowed full access through the firewall.
Your problem could also be related to Error Code 80048820
5) If other people can access the MSN Messenger service, and you are the only one getting Error Code 81000306, then you could look at your anti-virus software. Has anything changed recently?
6) One more thought, could your account be locked out? Try another account if have one, or can create a new account.
Dec 08, 2009 | Computers & Internet
When I try to sign in to Windows Messenger this error code:80048820 pops up. How do I fix this?
Sir,
Internet Explorer - Try removing the tick next to InternetExplorer 'Proxy server' settings, instead, go with the 'Automatically detectsettings'.
1) Launch Internet Explorer, click Tools and then clickInternet Options.
From the Internet Options dialog box, go to the Connectionstab.
Click LAN Setting. Un check the Use a proxy server for yourLAN (These settings will not apply to dial-up or VPN connections)checkbox. Finally positively tick: 'Automatically detect settings'.
Click Start (Button), and then click Run, type regsvr32softpub.dll. Restart MSN Messenger. Seealso Error code 81000314
3) If necessary, logon as a local administrator and set thecomputer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewallsettings such as Norton: "Block access to secure sites". If this cures the problem, make sure thatMicrosoft's MSN Messenger is allowed full access through your firewall.
a) Enter IP address 192.168.0.1 in your browser's addressbar.
6) If you are using IE 7.0 check the SSL Settings. Internetoptions advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 isto unplug, or restart your modem. Thisis particularly effective for cable modems.
8) We should have tried this solution before; check that theMSN site is 'up' 'available'. However,even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could tryphoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a bigupdate? Try disabling and see if thatcures the error.
10) A drastic solution is to try uninstalling MSN Messengerversion 8.0 or 7.5 and install Microsoft MSN version 7.0.
Guy Recommends: SolarWinds Exchange Monitor
Here is a free toolto monitor your Exchange Server. Downloadthe utility, then inspect your mail queues, monitor Exchange server's memory,confirm there is enough disk space and check the CPU utilization. This is thereal deal - there is no catch.
Free Download of SolarWinds Exchange Monitor
General, but classic Troubleshooting Techniques
Collect information: Write down exactly what the problemis. Something magical happens just bythe act of writing down the symptoms.
Ask: What was the last thing that altered on yourcomputer. Especially with changes toanti-virus software Reverse it!
Can you reproduce the problem: Occasionally trying againseems to make it work. Else you may geta different error from 80048820.
Locate the source: Hardware (modem) Software, your end orMSN site.
Phone a friend! Seriously do your MSN buddies have the same problem, if so it's thesite, if not - back to the drawing board.
Thanks
Oct 08, 2009 | HP Computers & Internet
Olve error code 80072ed quickly and easily
If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
1. Click the Tools menu, and then click Options.
2. In the left pane, click Connection.
3. Under Connection Settings, click Test Connection.
If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
4. Optional: Perform advanced troubleshooting
To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
5. Click OK.
When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
6. Try signing in to MSN Messenger again.
Hope I helped MSN expert Dr Reed
Sep 25, 2009 | Microsoft Windows Live Messanger
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
When i try to log into windows live msn it keeps coming up with error: 80048820 and says its my key ports?... I only recently downloaded this new msn and I don't know why it wont work all my other versions...
Unfortunately, there are many possible causes of error 80048820. This is somewhat of a generic error,
Lets try some easy trys first Check your System Date and Time.
sometimes Invalid proxy settings can sometimes cause the 80048820 error
sometimes your anti virus software can cause this error.
I would try and download the windows live one more time
Jan 27, 2009 | Computers & Internet
Fix Error 80070002
It only takes a few short steps to fix error 80070002
- Search for ppcrlconfig.dll (it should be in C:\Documents and Settings\All Users\Application Data\Microsoft\IdentityCRL\ppcrlconfig.dll), delete it.
- Remove all Windows Live Messenger and MSN Messenger installed.
- Reinstall Windows Live Messenger.
- Restart Windows Live Messenger.
Nov 10, 2008 | Microsoft Windows Live Messanger
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Microsoft Windows Live Messanger Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
