Question about Jl Audio 13W7 Car Subwoofer
I have a JL w7 13.5" with a 1000 watt v2 JL amp.
pjstanley
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
  • 74 Answers
SOURCE: I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
Posted on May 26, 2009
  • 3 Answers
SOURCE: how can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Posted on Sep 13, 2009
ASE TECH
  • 57 Answers
SOURCE: i got a jl w7 12 in a seald box runnin it with a
try looking @ your amp seeing if it is bridged if it is take look @ this video it might help you.
Posted on Jan 26, 2010
  • 257 Answers
SOURCE: How to wire the Pioneer Premier 12in. dual 2 ohm
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
Posted on Jun 09, 2010
How do i wire my 2- JL 1000/1 v2 amps to a single JL 13.5 dvc AE properly?
It is risky to do that ,but it can be done.This is not recommended without an Oscilloscope.
Mar 02, 2016 | Jl Audio 1000/1 Car Audio Amplifier
I am wondering what amp i would need for 2 JL Audio W3v3 - 2ohms. I am looking for something around 200. SHould I go with the Mono block and how many watts?
well you can go a couple different directions. you can wire them parallel or in series. parallel will get you down to about 1.3 ohms at the amp and series will get you close to 4 ohms. you need an amplifier thats stable at either of those impedances. the lower the resistance (impedance) the more power your going to get to the subs. I manage an electronics store and specialize in mobile audio/video. we are a 'Signature JL Audio Dealer' so i like to say i know the product line very well. JL makes an amplifier that is stable from 1.5 to 4 ohms and will put out the same amount of power at any impedance in that range which is really nice. Its called their 'Slash Series' you are looking for a JL Audio 500/1 amplifier. Grab an 8 gauge amp kit (4 gauge would over do it) and wire 'em up. Enjoy!
Mar 17, 2010 | Jl Audio 10W3v2 Car Subwoofer
Who to wire JL audio 12w6 to its max
Hello shermalestuc,
The JL Audio 12w6 v2-D4 has dual 4 ohm voice coils that can be wired for either a final load to the amp of 2 ohms (parallel) or 8 ohms (series).
If your amp is 2 ohm stable, the best power solution for a single sub is to use the parallel configuration, both positives and both negatives together and then to the amp.
Nov 08, 2009 | Jl Audio 12W6 Car Subwoofer
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
Jl Audio 13W7 Car Subwoofer Logo
57 people viewed this question
Top Jl Audio Car Audio & Video Experts
hoyzee1
matthew walsh
Level 1 Expert
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
