Question about GN Netcom GN 9120 Professional Headset
Pairing how can you tell which headset goes with which base/charger ?
No... But you can connect the headset to the base, unplug the base for about 20 seconds, re-plug the base and it should sync together.
Posted on Feb 10, 2009
At&t model dect6 troubleshooting
You probably just need to Pair the handset with the base again.
So, you have to set the phone in the main base, not just a charging base.
Some of the AT&T phones need you to disconnect the battery for about a minute to reset (this will not lose you stored numbers). Then pair the phone and base again.
Some models have a PAIR button on the bottom of the base.
Press and hold the PAIR button until the MUTE light on the headset base turns on (about four seconds) and release the button.
Return the headset to the headset base for registration.
Registration may take about 30 seconds to complete. The MUTE light on the headset base turns off. The headset ON/OFF light turns blue
on the first headset registered. The headset ON/OFF light turns orange on the second headset registered.
You should be good to go!
All the best to you,
Kerry Hostetter
May 11, 2014 | Computers & Internet
My voyageur pro ear piece is not functioning. It is not being recognized by the phone, nor is it turning on. Only when hooked up to charge does the red light turn on for two minutes and then it goes off. I...
You don't mention which headset you have. It may be that the headset is dead or that you need to re pair it to the base. Plantronics has a # for tech purposes:
1-800-544-4660 x 5538
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Radio Communications
Phone lifter not working. light on top of base not lit up
Try re-pairing the headset to the Plantronics 500A base unit, it sounds like the headset may have lost connection with the base. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Good luck from Headsets Direct!
Jul 06, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My plantronics CS50 USB headset won't subscribe to the base, it just keeps giving 3 short beeps when the call button is pressed. Numerous attempts at resubscription and resetting have not had any...
I know this is an old post but I just want to share what I confirmed through Plantations. Hopefully it will help someone in the same situation. Sometimes, people buy replacements headsets and it should be noted the CS55 Headset does not pair with the CS50 base. While they headset looks identical, the only way to tell which headset you have is to open the battery cover and look under the battery. If you have a CS55 headset and a CS50 base, they will not pair.
Jun 24, 2011 | Plantronics CS50-USB Headset
Headset not working. red light on base is flashing and yellow light is static; no blue light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Feb 09, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The base on 500a will not pair it flases then light goes out
Try leaving the 500A base unplugged (overnight if possible). Make sure your headset is charged, and then try the repairing mode. In a way this is resetting the base by letting all of the power drain out of it and starting fresh.
Feb 08, 2011 | Plantronics Voyager 500A Deskphone Adapter...
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
Plantronics 220
Try pairing it like this: Put the phone into pairing mode. Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue. The units should link up together.
Aug 15, 2008 | Plantronics - Bluetooth Headset Plus Base...
GN Netcom GN 9120 Professional Headset Logo
1,137 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
