Question about Yamaha DSP-A1000 5-Channel Amplifier
Auto Shut Off After 3 Seconds...?
Recently, I purchased a Yamaha DSP A1000 (older model, probably early 90s but one of the pioneers in surround sound) and it played fine when the person I bought it from played it for me. I got it home, hooked it up to my ipod and some Klipsch KG4 speakers, and it worked for about 10 min. before shutting off. Now, every time I try to turn on the amp/receiver it shuts off within about 3 seconds. Every attempt to change this has resulted in failure. I am sure this has something to do with the 6 ohm min amp being hooked up to the 4 ohm speakers, but find it strange as the guy I bought them from has owned them for about 15 years and never had a problem. Is there a way to disable this protection system or is it good that it is enabled? I'm hoping to avoid a repair shop as it can get costly quickly, and I already spent $300 on the amp, 2 KG4 speakers, and a Carver CT-7 Tuner.
It clicks and turns off after 3 seconds, even when no speakers are hooked up to it...
  • dalip143 Jun 20, 2008
    My Yamaha is dead nothing when turned on there is no display only the relay clics input selection control turns litle and shuts off any sugestons please.
  • 236 Answers
Either your DSP output stage already damaged or maybe your speakers. have it both chekced for short. or worst both of them. DSP A1000 can drive as low a 4ohms on main channels but how is the power handling of your speakers? are you sure it has not exceeded the capacity of the speakers? or maybe you have over driven the speakers and they are still ok but your amp gut busted due to over drive. If the DSP amp is busted then it is due for replacement of power transistors and drivers. you can not disable the protection circuit. at least the design. it can be disabled by a tech person with a lot of modifications but i wont go for that or it can cause more damage to your equipments. i am from yamaha before and i have made conversions of protection circuits but it is too risky.
Posted on Aug 04, 2008
Dsp-a1000 center channel has a very low volume
By opening a new incident you are losing all that good thread (*) we were already working on and you will probably have to re-explain everything to whoever chimes in going forward.
Jul 14, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha dspA1000
Be sure you are using the AUDIO OUT on the vcr then going into a AUDIO INPUT on the DSP A1000, this will allow the DSP A1000 to amplify the audio line level.
Jan 31, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Jan 14, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A3090: All video settings trip unit and it turns off
Is the first set "stereo" settings and the 2nd set "surround" settings?
If so that may mean that the surround speakers arent all connected right.
Jan 14, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
No center main volume
Make shure your initial setup on the amp is for center as an active speaker,then to check volume on center at zero. Possible to check speaker and wires for open or short.BIGRED
Sep 16, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 5-Channel Amplifier Logo
369 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
