Question about GE DBSR453EBWW Electric Dryer
Refrigerator not cold enough
G e refrigarator with side by side doors model #GSS22JEPA . have turned up temp control 2 times 12 hrs apart and is staying about the same temp
You may need to check to make sure the drain pan below the fridge is emptied and cleaned out. another thing to do is clean off any cooling fins under or behind the fridge.
Another thing is do you hear the fan running at all? One time I found a plastic sack caught into the fan, and that burnt it out.
If nothing else, you might need to see if the compressor is working correctly.
Good luck.
Posted on Jun 13, 2008
Temperature controller of the LG GLD 292 RPJL is off, what can I do?
MAY HAVE a bad cold control thermostat, however the setting should never both be set to high. 5 may be a bit to high they should be set at medium. otherwise I suspect u may have a bad control board issue not communicating with the cold control all can be checked with a multi meter
Mar 13, 2015 | LG Refrigerators
Hi my refrigarator is not cold lost fridge temp
I have the same fridge its the sensors there hidden behind the back panel. there are 2. one at top and one at bottom. one of them will faulty. there cheap to buy and easy to fit.11_16_2012_11_30_22_pm.jpg
Nov 16, 2012 | Samsung RS2630SH Side by Side Refrigerator
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Refrig and freezer not cold enough It was working fine until a few days ago. I put the temp controls to full cold and it is still warmer than normal. It is an older WP side by side model ED25PQXDW83
Only adjust one control one number at a time and wait 24-48 hours before adjusting again. Set both controls at the mid setting and start again. Check the coils underneath and make sure it has been defrosting. A problem in these 2 areas will cause your symptoms.
Eric
Oct 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side refrigarator Mod, RSW2400EAE refrigarator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
Never shuts off.Too cold
Try defrosting.
if you can move everything out unplug ,turn it off w/ doors open 6 to 12 hrs this will free up any clogged tubes. Set it at a low setting and keep an eye on it, If this doesn't work your thermostat may be going out.let me know.Good luck.
Len West
Feb 16, 2009 | KitchenAid KSRS25IL Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer and refrigarator are not getting cold enough
maybe thats why they sold it??? you could try changing the ther,ostat to see if that dosent help
Nov 16, 2008 | GE Refrigerators
GE DBSR453EBWW Electric Dryer Logo
98 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
