Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II
No power to the face even after I checked the handle latch/power break switch. I also checked the wall plug for power and it is alive.
  • Anonymous Sep 23, 2008
    Hmmm...don't believe there is no HOME FIX, as I have the same problem too. I'm investigating it. I have found that when I close it the door, sometimes slamming it, the power to the face panel comes back on. Tells me there is either a loose wire connection and/or a latch problem. Either case...will report findings as I'm working on it the next couple of days.
  • Anonymous May 23, 2009
    The latch does not cause the door to lock properly and the metal piece will fall out
Take the back of the door off and remove the panel where all the wires lead to. If you look at the handle that holds the door shut there are 4 wires on a connector there on its switch. There should be a brown one. Follow that wire back and about 12 inches later there is a little switch it connects to. That switch is your problem. Remove both wires connecting to it, splice the 2 wires together and your dishwasher should work fine until you get the actual replacement part. If not you can just leave the wires spliced and it will still work fine. Hope this helps.
Posted on May 30, 2009
  • 126 Answers
THERE IS NO HOME FIX.BEST YOU GET A TECHNICIAN TO ASSIST.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
On my whirlpool quiet partner II, I have absolutely no power in the control panel. I've tried the plug, it's live. I've also tried the power supply both under the toe-kick and at the...
Very likely the fuse that clips onto the control panel is blown so ya have no power to the control board. This tip i wrote will show ya where exactly that fuse is and how to check it.
http://www1.fixya.com/support/r10341846-will
GENE
Oct 04, 2011 | Whirlpool Dishwashers
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
Whirlpool Quiet Partner II. Does nothing at all when you try to start it. Seems latched tightly and I double-checked and reset the circuit breaker. Thoughts?
CHECK THAT THERE IS VOLTAGE AT THE CONNECTION TO THE D/W. CHECK WALL SWITCHES, GFI OUTLETS FOR TRIPPED, THAT THE WATER TO D/W US ON. IF IT TRIPPED CIRCUIT BREAKER. MAY BE SHORTED INTERNALLY.
Mar 10, 2010 | Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Quiet partner ii just stopped
Most likely it has an internal fuse or relay gone bad. Check the curcuit w/ a "glow stick" power identifier available at Lowes or Home Depot.
Aug 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,609 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
