Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 My auto focus function stopped working
  • 2 more comments
  • sbhoward5 Dec 02, 2008
    When I try to take a picture in auto focus mode the camera does not work. By not working, I mean that it will not take a picture. It will not snap the shot. In manual mode the picture is blury but it will snap the shot.
  • taylorrm Dec 25, 2008
    I have a Nikon D80 with a 18-135mm lens and I was adjusting the self timer and I got a F-- sign and my camera stopped taking pictures. I looked that problem up online and they said it was a problem with my lens, so I took off the lens and put it back on. The camera started taking pictures again, but it will not automatically focus. I do not know what to do.
  • Rebharrop Jan 10, 2009
    I have the same issue - have had it a number of times and used to be solvable by un-mounting and remounting the lens, but recently it won't auto focus at all no matter what I do. Makes a terrible whirring noise and is unable to find correct focus. Reset does nothing and neither does pressing AE-L button (I do not have AE-L/AF-L setting menu as described in the manual however so I am off to search for a software upgrade see if that helps.
    It is fine as manual focus.
  • Satdeep Marwaha May 11, 2010
    Stopped working completely? With any lens?
    Or do you have to choose focus points instead of the camera doing it for you?
    Please clarify.
Awesome....it's what my problem ended up being...thank you!
~Suzanne
Posted on Feb 12, 2009
    Novelist:
  • 121 Answers
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again.  Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5, check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
Posted on Jan 02, 2009
SOURCE: Nikon D80 auto focus
Just like ladylaine, above, I had this same problem suddenly today. After fiddling with all the settings and just about assuming I'd have to send it in for service, I found this page, read her suggestion, and turned my lens all the way counterclockwise. Sure enough, a tiny click and now it's working fine. It just had become slightly unseated somehow.
Posted on Sep 11, 2008
  • 104 Answers
SOURCE: Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Posted on Apr 11, 2008
I had the same problem but then I realized the lens was not "in" all the way.  It had not clicked into place when I changed lenses.  This might work for you....it did for me.
Posted on Jun 05, 2008
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
  • 77 Answers
SOURCE: D80 nikon autofocus. when i look through the
kindly set on auto central focusing setup by using menu option
Posted on Nov 01, 2009
D80 Digital Camera with 18-135mm Lens: My nikon d80 will not auto focus when I push the s...
The r11 is in the lower right of the top LCD or view finder that is in the D80 manual page 36 it speaks about the buffer. The r with a number is how many shots the buffer at that moment can handle. It is not an error message. For auto focus issue is the lens in AF as well as the camera?
May 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
My Nikon D80 won't shoot multiple pictures when in sports mode.
Please read page 36 in the D80 manual. What you are looking for is just down from the top, "Continous".
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 nikon camera was not working specially on
Check the following:
- Make sure your lens is screwed on correctly. Try to remove it and put it on again.
- Make sure the dial is squarely pointed to Auto
- Make sure the Auto-Focus switch in front of the camera is turned to A (not to M)
Dec 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 auto focus broken
AF lenses normally have a subtle grinding noise when used. Make sure your AF switch is turned on. If this still does not work, you may wanna consider bringing it in for repair
Dec 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Quantaray lense
Yes, the Quantaray Autofocus lens will focus automatically on the D80.
Sep 27, 2008 | Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
386 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
