Question about Western Digital Computers & Internet
My desktop is not detecting this device.... what is the procedure to connect... pls let me know step by step
    Novelist:
  • 112 Answers
Sir,
1.You need to connect the device to your Pc using the specific mode of connection,USB or an
internal port.
2.Then you need to install the right drivers for that particular device.The product should come
with the Driver/software installation CD.
If you specify what device you are trying to install,then we could help you further more.
Posted on Nov 04, 2010
Why does my tomtom keep going back tro demo mode
unfreeze tomtom sat nave
frozen tomtom
To fix the errors, you must run the TomTom Clear Flash tool. This tool clears the flash memory on your navigation device.
Select your operating system:
Windows To download and install the TomTom Clear Flash tool on your navigation device, follow the steps below.
Note: The download steps apply to Internet Explorer 8. The download steps may be different if you are using another browser.
  1. Download the TomTom Clear Flash tool: Note: The download procedure applies to Microsoft Internet Explorer 8. The download procedure may be different if you are using another browser.
    1. Click the Download button. downloadbutton.gif TomTom Clear Flash tool for Windows (EXE)
    2. Click Save.
    3. Select the Desktop and click Save again.
    4. Click Close.
    5. Connect the navigation device to the computer:
      1. Turn off the device.
        Note: If the device is connected to the computer, for example for charging, disconnect the device.
      2. If the device uses a memory card (SD card), insert the memory card into the device slot.
      3. Connect the device to the computer.
      4. Switch on the device. The computer detects the device.
      5. Run the TomTom Clear Flash tool:
        1. Double-click the file clear_flash.exe, which you can find on your computer's Desktop.
        2. Select the language. Read the Licence Agreement, then select I Agree. Click Continue or 1751_01.gif.
        3. Install TomTom Clear Flash is already selected. Click Continue or 1751_01.gif.
        4. Click Continue or 1751_01.gif.
        5. Click 1751_01.gifagain to start the installation.
          When the installation has finished, the message Installation complete is displayed.
        6. Click OK or 1751_01.gif.
        7. Click 1751_01.gifagain.
this worked for my device where NOTHING else would, the original problem seems to come from updates. My device does not keep its settings What should do
Aug 14, 2014 | Tomtom VIA 1605M GPS w/ Lifetime Maps...
Toshiba Tecra M1 what are hdd format procedure?
Formatting a laptop is the same as doing it on a desktop computer.
If you are using the Windows installation CD then to get the laptop to boot up with the Windows CD you can change the BIOS boot startup device and make the CD the first boot device.
Apr 24, 2012 | Toshiba Tecra M1 PC Laptops
Reload software 513
Due to the Java Virtual Machine (JVM) error, the device will not show a Connected state in the Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader. .
To Fix this problem,please go on this link to know the step by step procedure.
CLICK HERE
I hope you can fix this problem...
Jul 22, 2011 | RIM BlackBerry Storm 9530 Smartphone
My laptop XP is not detecting Transcend StoreJet 25 External HD 500GB, but in desktop XP it is very well detecting and working. Pls let me know the solution for my laptop
USB devices draw electrical power through the USB cable.
Sometimes, the power-output from a USB port on a laptop is _less_ than that of a USB port on a desktop computer.
Hence, there are "Y" cables -- connect to two USB ports on your computer, and to the USB device at the other end, to draw more current.
Which manufacturer of laptop?
Which model-number?
Which Operating System?
Do other USB devices work when connected to the laptop's USB ports?
Nov 09, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Usb port not recognized any device
  • Don't worry just follow the simple steps and get rid out of that problem
    • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Hub Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed.
    1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
  • Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 29, 2010 | Acer Veriton 7600GT PC Desktop
Cant use my usb
Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | Toshiba Satellite M35X-S311 Notebook
USB Port not Detecting any Devices
Before i can suggest any steps i need to know since when u have this pblm and what are the softwares and hardwares you had installed recently,please revert back with details for more assistance......:)
May 16, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Dont know how to install pk 635m
Hi
The general install procedure for USB devices is to install the drivers/software first then connect the device. The PC should then detect and initialize the device.
I however recommend you check and follow manufacture's guidance/steps.
If you don't have the drivers/software, download the drivers/software and instructions from the link below.
http://www.a4tech.com/en/download3.asp?ID=142
Mike
Mar 28, 2008 | A4tech PK5
How to install my a4tech web cam?
Hi
Mike
Mar 19, 2008 | A4tech PK5
Computers & Internet Logo
228 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
