My laptop is not communicating with my GC83 EDGE PC card
  • 3 more comments
  • motiveflow Jun 13, 2008
    everything warns NOT to install the card before the software. The software loaded fine, but when i insert the aircard, i get the message "GC83 is not communicating. please reinsert the card"
    When i do that, the screen goes to all vertical lines and the computer locks up. i'm far from getting online. the card won't even talk to the software.
    it's and acer 5100 running vista
    The owners manual has nothing under troubleshooting remotely like this message. tried the drivers already. same message.
    there's no physical damage to the slot.
    i tried updating the drivers for the slot and there was no change.
    i don't have any other way to test the aircard.
    i will have to assume that it is defective.
  • Nathan Ayers
    Nathan Ayers May 11, 2010
    are you able to test another type II card to make sure the slot is working properly.
  • Nathan Ayers
    so when you plug it into the pcmcia slot it reads it and installs it correctly? your just not getting a signal from it? or its connecting but your not able to go online with it. also what kind of laptop is it. what operating system are you running. all these thing clarified would really help to be able to help you with your problem
    Sergeant:
  • 243 Answers
Cause you can update the expansion slots drivers. but i would also if you can test this card on another machine or a friends laptop to ensure its not defective.. but if the card works properly then upgrade the drivers of everything, i.e. expansion slot, processor, firmware for the aircard, and the wireless manager. cause what i can tell after talking to tech support for sony erickson. they said it sounds as if the expansion slot is not working or the card is defective. i hope this helps you keep the comments updated and i will be glad to continue assisting you..
Posted on Jun 13, 2008
    Guru:
  • 1,342 Answers
Click HERE to update your drivers and download your User's Manual.
  • Georgia B
    Georgia B Jun 13, 2008
    If you're getting vertical lines it sounds like a hardware issue. Get a flashlight and look inside the slot for bent pins.
Where is the wireless communication switch on toshiba labtop
Depending on the model of you Toshiba Laptops. it is mostly on the Left side of the laptop. some infront edge of the laptop. tried to check on the sides(edge) of it. it is a small slide switch that says on/off and it has an icon like this:
Aug 12, 2011 | Computers & Internet
Intermittent HSDPA coverage using Sierra Wireless 860 card???
i woudl try runing cleaners 1st www.ccleaner.com and ace utilties get out junk thats choking it up and downlopad latest drivers from websites from today cheak ok then make sure u have all latest updates for windows installed
Jan 30, 2008 | Sierra Wireless Aircard 860 PC Card...
My laptop will not start it says to reseat the memory, how do I do this please,thank you
Turn off your laptop.
Flip it over.
The memory is usually behind the smallest cover. The other covers are for the hard drive or drives.
Open the cover for the memory cards. If you open the wrong cover close it and try another.
The memory cards are small printed circuit boards about 2 1/2 to 3 inches long and about 1 1/4 to 1 1/2 inches wide.
The cards are in sockets and they 'clip' in. To remove a card look at both sides of the card. There will be a place on each side to push on the clip with a finger. Push on both of these spots gently at the same time. If you do this correctly the memory card will pop out of the socket allowing you to remove it. Remove the card and if there is more than one remove the others also.
Once you have the cards out I recommend cleaning their contacts if possible. (This is optional.) Use a clean pencil eraser and rub it gently along the contacts (they are gold plated) to remove dirt and oxidation.
To reseat the memory place the edge of the memory card in to the slot laptop it came out of. The cards will only go in one way. There is a notch on the edge that must line up with the socket.
Once the edge is in the socket gently push the card down in to the metal clip. It should click in to place. Make certain that the card has gone in straight and not crooked . Also look at the edge of the card. The gold contacts along the edge should be 'seated' and line up evenly in the socket.
Install all the memory back in to the laptop.
Replace the memory cover.
Flip the laptop over and restart it.
Hope that helps.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error Message: 104-Unsupported wireless network device detected. System Halted. Remove device and restart.
I think you can try this steps and hope it will help you.
Try to reseat the Wireless Card in your machine.
You will need the following tools to complete the removal and replacement procedures:
-Magnetic screwdriver
-Phillips P0 screwdriver
-5.0-mm socket for system board screwlocks
-Flat-bladed screwdriver
-Tool kit-includes
Turn the machine upsidedown
Remove the battery.
Wireless Card Removal
1. Loosen the PM2.0×5.0 screw 1 that secures the Mini PCI
compartment cover to the computer.
2. Lift the rear edge of the Mini PCI compartment cover 2, and
then swing it forward.
3. Remove the Mini PCI compartment cover.
4. Disconnect the wireless antenna cables 1 from the Mini PCI
communications card.
5. Spread the two retaining tabs 2 that secure the Mini PCI
communications card to the communications compartment
socket. (The board rises up).
6. Remove the wireless communications card 3 by pulling the
board away from the socket at a 45-degree angle.
**Reverse the above procedure to install a Mini PCI
If happens that it does not work, I think you can just reinstall OS just to make sure if its Hardware or Software problem.
Thank you for choosing FixYa.
Apr 24, 2011 | HP Compaq Presario V2000 Notebook
Connection problem
The phone working when the PC doesn't...
Not a good explanation for that...
Check the path between the main system
and your modem to see if you have a motor (refrig), or
fluorescent light... or even an old style (CRT) monitor/TV
can NOISE up a radio signal really well...
(to get past any wires that may be in a wall)
Rotate or raise the modem's physical location...
But for the phone working I would suggest getting into the
WAP and turning up the radio strength...
How far away from your modem is your system placed...??
((or consider a good WAP "extender" (like Netgear))).
Carnac the Magnificent
Apr 09, 2017 | IBM GC83 EDGE / GPRS (26K3393) Modem
Sony ericsson gc83 to unlock
Cingular usually has a standard pin# of 0000. If this does n't work contact cingular they might not be compatible with each other. I have been a cingular customer for over 10 years, and have found majority of what they have works within there own equipment. trying to use the pc card with t-mobile, although it is a great Idea, and makes sense, I believe it is a compatability issue. makes some calls, and if you dont get the answer you like from cingular, call and talk to tech support from both sides t-mobile, and cingular.
Apr 12, 2009 | Sony Ericsson (GC83) Wireless Adapter
I nedd Mobidata usb edge modem drivr
Pls I want you to help solve this problem for me... I have a Novatel Modem with number Merlin U740.. I missplace the DC drive to install the software into my laptop.. so what should I do now to make use of it.
Thanks
Esajumi
Jan 28, 2009 | IBM GC83 EDGE / GPRS (26K3393) Modem
Driver problems
welcome to fixya
you might want to goto sony website and see if they have the downloads if not
you can also try drivers.com or driversupdate.org both very good website
hope this helps out have a good day :)
Jul 17, 2008 | Sony Ericsson GC83 (797553009054) Modem
Computers & Internet Logo
David Payne
David Payne
