Question about Konica Minolta DiALTA Di200 Copier
DIALTA DI 2510 CPIER DISPLAY CO500 - Konica Minolta DiALTA Di200 Copier
  • Anonymous Mar 18, 2014
    MINOLTA DIALTA Di 181 SERVICE ERROR CODE CO500: CALL SERVICE
  • Anonymous Mar 26, 2014
    will continue to boot
  • 1,110 Answers
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. You need to locate the small hole in the panel which has a small switch behind it. It is located just to the right of the panel reset button, over the edge of the panel. You need a small paper clip or a tooth pick to insert into the hole to activate the switch. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see the initial screen come up. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. Touch the "Trouble Reset" box to reset the code. Then turn off/on the machine. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 04, 2010
Minolta dialta di 181 CO500 service call
Press the Trouble Reset Switch on the master Board for this fusing malfunction. Remove rear cover to gain access to control board, small little black switch, power must be on to do this be careful if the code come s back buy a new fuser unit, if you can find one. Quite old machine. DO NOT CONTINUE TO RESET the fuser can catch on fire that will ruin a perfectly good day.!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 22, 2017 | Minolta Office Equipment & Supplies
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Dialta di 2510
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 23, 2014 | Minolta Office Equipment & Supplies
Dialta di 2510 errore c0000
Main Motor failure. Try first removing the image unit and reseat it. Then check behind each paper draw for paper. Then you might have a bad main motor or the control board that controls the motor is bad. I would have a Konicminolta Tech look at it. Drum been replaced lately?
May 01, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
COPIE AVEC FOND NOIR KONICA DI 2510
Clean the glass ,mirror,lens or change the starter/developer.
Jan 25, 2013 | Konica Minolta DiALTA Di200 Copier
Dialta di 2510 has code COBAO
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the trays has to just touch them.
Nov 14, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
Copiadora pitney bowes dl 200 error en dispey co500 lla puse tehrmistor y sigue igual como se resetea este codigo
The problems is in the fusing unit.Clean the thermistor and heater lamp.Reset the trouble:press the microswitch located in the right side to display pane,under the display contrast button.After appair the * simbol on the display,press 3 and the Trouble reset button.
Aug 07, 2010 | Konica Minolta DiALTA Di200 Copier
Error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
1,642 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
