Question about Acer MF35 MP3 Player
Hi I have USB drive 4GB its give message of write protection and also some time I/O device error when copying some files plesae give me solution for this . thanks
mewms_14904
  • 1027 Answers
SOURCE: USB DEVICE NOT RECOGNIZED
This link is for the downloads for your laptop. The downloads are viewed as a pdf with links to the software/firmware. On page 2 are the webCams there are 3 different manufacturer, logitech, bison and Suyin.
Posted on Apr 17, 2008
SOURCE: USB Write Protection
NO its not helping
Posted on Jul 01, 2008
SOURCE: how to remove write protect on my usb flash drive
how to reamove write protected folder ?
Posted on Nov 07, 2008
  • 3 Answers
SOURCE: Removing write protection from Flash pen drive
try this
1) In My Computer, right click on the drive letter of your pendrive and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, GREAT!
5) If it DIDN'T work, repeat steps 1 through 4.
or this software
http://www.apacer.com/en/support/downloads/HS2.0_Utility_LFormat.zip
or this
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
visit us for more info http://gilablog.com
Posted on Nov 19, 2008
  • 144 Answers
SOURCE: during any little movement gives (unknown usb device connected)
This sounds like a loose USB port. Have yo accidentally jolted it before by accidentally hitting a flash drive or a projecting USB plug. If so then it might be a loose plug on the motherboard and if one of those plg connectors hits another it will think there is a new device and try to install it. Take it to a shop or if you can go to www.repair4laptop.com and look up how to disasemble your laptop. Then resodder it in place - or take it to a shop. It may be expensive but the risk of damaging something else is less.
Posted on Dec 07, 2008
I have my pics in memory card & its nt copying to my computer . its error coming in it parameter incorrect then hw i can copy my images & i dont want loose those images???????
C:\Users\Bob\Downloads> copy Update.iso F:\
will take you here
Why is the second file copy failing?
The hint is the file extension: *.iso, which suggests that this is a CD or DVD image, and DVD images have the feature that they tend to be really big.
Like more than 4GB big.
USB thumb drives tend to be formatted with the FAT32 file system rather than with NTFS. And FAT32 has a maximum file size of 4GB minus one byte.
The user confirmed that the Update.iso file was larger than 4GB and that the USB thumb drive was formatted as FAT32.
Mind you, the error message doesn't help at all in identifying that this is what's going on. I don't know where it's coming from, but my guess is that somewhere inside the copy command, it tries to create the destination file and set its file size. Since the file size is out of range for FAT32, the call fails with the error ERROR_INVALID_PARAMETER, and that's what ends up bubbling out to the user.
But at least now you know what the confusing error message is trying to tell you.
hope this helps
Jul 03, 2012 | SanDisk 4GB microSD High Capacity Memory...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My computer is not recognizing my 4gb Cruzer, after an architect copied some files to it. How can I access it?
First, let me say that sometimes my PCs, even newer ones, want to start slow with my own 4GB Cruzer attached, and I have to unplug it and wait 'til Windows starts... Secondly, since you say your PC isn't recognizing it AFTER an architect copied files to it, I would think that perhaps the architect is using some security software to lock the device. Some USB devices have built-in security--some even have a tiny little physical lock on the side to prevent accidental erasure and protect them as well. If your architect formatted it at any time to put the file on it, I'd say look at security features being employed to protect it. Of all the arts, engineering and architecture are two of the biggest fields where copyright and design is a commonly protected thing, and there's a chance he/she even forgot his PC did this to any software copied to USB flash devices connected to it.
If his file(s) were created in Linux, or another OS, there's also a chance he formatted the flash drive to make it recognized by his own OS. Hope not--he should know it probably wasn't necessary , as Linux-based OS's also 'see' Windows-style file structures, like NTFS.
Hope this helps.
Feb 24, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
Aug 05, 2009 | Sony Computers & Internet
USB Drive - Write Protected
Hi.
While formatting chose default allocation unit.
If this doesnt helps the tell me.
Regards
Faraz
Oct 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Acer MF35 MP3 Player Logo
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
