How are you? My name's Richard Park. I put some paper into paper tray and click "ok" for printing.After arranging the printer, when it starts and slide in paper along the tray. But it has jamming. It doesn't put a paper into printer catridge. Always the Edge of the paper is folding, Appear "Error Message" on the screen, so I can't use this printer. But CD/DVD COPY IS OK. How to solve this problem? Please....
  • 1,650 Answers
People, please use the correct product category, and provide the brand and model number of whatever device has you asking for help!
I deduce this is some sort of printer, but I can't figure out where the CD/DVD COPY comes from; I never heard of a printer that also copies optical disks.
Assuming it is conventional paper printer, there is probably a shred of paper stuck inside the printer from a previous jam. It isn't in a paper jam sensor, since the printer doesn't detect it. When the new sheet of paper goes in, it gets bent over by the paper shred and jams. You should be able to figure out just where the offending piece is by carefully noting how far the sheet went before it was stopped, and examining the folded-over part to identify how far from the edge of the paper path the foreign object is located. You may have to use a dental pick to extract the shred, paper clip or whatever it is. Be patient and be careful not to break anything. If the problem is a paper shred, you may have to tear it apart and pull it out in pieces because it is probably all bunched up and stuffed in tightly. If in doubt, consider partially disassembling the printer to get at the problem area.
Posted on Nov 04, 2010
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 19, 2011 | Dell 3010cn Laser Printer
Error message says "Paper tray
If printer is connectedto a network, type the printer IP address into the address field of your Webbrowser. Click on Configuration and select on paper menu and make you have thecorrect settings. Make sure you selected the correct paper source and papertype. Make sure on yourapplication, the print settings matches with the printer. Check the printsettings of the application that you are using. For example if you are usingMicrosoft Word, you need to click on print and click the properties button andgo to the paper tab. From the Paper Tab windowyou can modify the Input options like paper and the source (paper tray).You may click on the drop down and select "Automatically select" for paper trayand select "Use printer settings on paper type and then click OK. For further assistance,please contact Lexmark Technical Support.
Apr 08, 2011 | Lexmark X500n Color Laser All-in-One...
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Its prints one page at a time and a pop up appears that says "press cancel button (manual feed mode)". I do this and nothing happens. Why will it not just print the entire document at one time? I...
You need to change the default tray. Thats the reason its printing one page at a time. You can change the default tray to draw paper from two ways, by using the controls on the printer itself or by changing the settings when you print a document.
To change it on the printer, go to menu on the printers keys and scroll the options until you find the print settings. Use the up and down arrows to scroll and press enter or OK when you find print settings. Continue to scroll until you see the default paper tray and change it from the manual feed choice to the default paper tray.
If changing from the print settings in the computer, when in a document that you want to print go to file at the top of the page and then print and click on preferences. Click the tabs at the top until you see the paper tray that is currently being used and click the arrow next to it to change it to another. Then click "ok" and close everything.
Dec 07, 2010 | Samsung ML 2010 Laser Printer
Trying to print microsoft excel spreadsheet printer keeps saying load tray A4 both trays have paper whats going on
This isn't actually a problem with the printer, but with Excel's print preferences.
In Excel, select File->Print to bring up the print dialog.
Select your Dell 3100 if it's not the default, and then hit the Properties button just to the right of the printer name.
On the printer properties dialog, there's a field named "Paper size"
Click on that field and select "Letter (8.5 x 11 in)" You may have to scroll to find this selection.
Hit OK to close the printer properties dialog, then hit OK to print your worksheet.
If this helps, be sure to hit the "thumbs-up" for me!
Dec 24, 2009 | Dell 3100cn Laser Printer
Konica Monolta c550. ignores trifold
the fold function is only available when the option finisher fs-608 is installed . here is the steps to make a trifold on a fs-608.
1 open a one page document it can only be 8.5x11 in size.
2 click file then print and pick the konica c550 in the printer name box. click properties.
3 in the output method select print leave the paper tray on auto leave the paper size on same as original click original size to indicate 8.5x11click on the radio dial to indicate portrait under original orientation.
4under the layout tab leave the following fields blank-combination,rotate 180,skip blank pages,binding margin and image shifton the right side of the layout screen leave print type as one sided and binding direction on auto.
5 under the finish tab leave paper arrangement at its default= prioritize arranging papers.make sure there is a check mark in the fold box and select trifold in the drop down menu.
6 click ok and go to the c550 to retrieve the document
Nov 05, 2009 | Panasonic DP-C264 Copier
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
