Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
Double Oven says "F0" and beeps continuously
My Kenmore double oven beeps multiple times, shows F0 then beeps continuously.
  • Anonymous Nov 08, 2008
    I just paid over $$350 to replace control board. Worked for 2 months. Now it has started beeping again. I will NEVER get another Krnmore appliance!
  • Karen H Dec 08, 2008
    We have the same problem with our single oven. I occurs once in a while when baking. The only way we were able to stop it was to turn off the circuit breaker and turn it back on after a few minutes.
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Posted on Jun 17, 2008
Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
I have a Kenmore 30" double wall oven model no. 911-41185. It will not let me do anything and keeps displaying FO and beeping. Can you tell me what is wrong?
F0 means no error. press cancel to clear display.
If you cannot then that key might be stuck, just a guess. I have your tech repair manual with failure codes and troubleshooting on page 43. This NOT a user guide. It is meant for qualified peeps. So be careful. Late model double oven tech repair manual HERE
Feb 06, 2010 | Ovens
Kenmore double oven keeps beeping and shows error code FO
Hello there:
F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Dec 31, 2009 | Ovens
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
An F0 lights and beeps on the pannel for the bottom oven
F0 typically means a shorted OFF key. You can trouble shoot this with an ohmmeter. Turn off the power. Disconnect the ribbon cable. Check flat cable pins 13-14. Normally the ohmmeter should show an open circuit. Press the OFF key. The resistance should be 100 to150 ohms. If all this turns out to be normal, there is probably an intermittent short circuit. Try my fix at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have share this with over 1360 folks and most report success.
Let me know at Hutchipop@yahoo.com
Nov 03, 2007 | GE Profile JTP56 Electric Double Oven
F0 error
This may be related to a problem that I have helped others solve. The solution is free and can be found at my website which is: http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf It has helped over 1000 folks with a similar problem. Hope it works for you too.
Aug 08, 2007 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
760 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
