Question about Sport & Outdoor - Others
I have a 1985 suzuki lt250ef quad. It wont start and when I check the spark it seems to fire 3 or 4 times per rotation. Can anyone help with this?
  • 9 Answers
SOURCE: Harley Davidson will not start
you say at times its fireing. sounds like ignition problems. does it have points? if so they may me worn out. I have an 87 sportster evo that has points in it.
Posted on Jan 21, 2009
  • 3567 Answers
SOURCE: quad starts but won't stay on?
ALWAYS have a fire extinguisher at hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on May 06, 2009
wd4ity
  • 4565 Answers
SOURCE: suzuki gn125 wont start. checked carb, cdi, coil.
Check the valve adjustment. If a valve is standing open just a little, the compression will be too low to start the engine. Check fuel delivery by dribbling a little gasoline into the carb and try starting the bike. If it starts and runs for a second or two, you're not getting fuel into the cylinders. Check you carb again.
Posted on Oct 19, 2009
Adrian762
  • 425 Answers
SOURCE: suzuki 250cc quad bike wont start, just clicks
Three causes:
1: Dirty battery terminals
2: Battery is flat or dying
3: The starter motor is dead and all that is happening is the solenoid is clicking in and out
Posted on Feb 05, 2010
  • 21 Answers
SOURCE: my RAM 100cc quad bike wont start.
You need to check if there is any leaks from the carb to the motor. Make sure the carb is clean. An airleak could prevent the motor from starting as well as checking the carb itself ....the floats the jets things in that nature.
Posted on Feb 13, 2010
Wiring diagram for 1985 suzuki 250
Hi there by any chance does anyone have a copy of a wire diragram for a Suzuki quad runner LT250 1985 please
CHEERS
Feb 20, 2013 | MotoBatt 1985-1986 suzuki lt250ef...
96 bandit, wont start,will turn over but not fire up, have changed plugs, drained carbies, checked for spark, still not firing up, any ideas?
check fuel filter and shut off in float chamber , if you have spark and gas , still not firing check timing .
Mar 18, 2012 | 1996 Suzuki GSF 600 S Bandit
I'm having trouble starting my 1985 rm 250 and I
It means that unburned fuel collected in the exhaust pipe then ignited when the spark plug fired due to the rotation of the crankshaft. It also means the spark plug is firing and the cylinder is getting gas... too much gas. The engine is flooding out due to much choking of the carb during kick starting.
Aug 16, 2011 | 2003 Suzuki RM 250
I NEED THE DISTRIBUTOR CAP FIRING ORDER FOR A 1985 OLDS. CUTLAS V6.
1985 Oldsmobile Cutlass Salon 3.8 liter V-6
Hope this helps.
Aug 17, 2010 | 1985 Oldsmobile Cutlass Salon
After travelling over 15 miles say 10-20 minutes the bike wont start and yet if left 20 minutes or so will,any suggestions1986 Goldwing Aspencade
Had the same problem on my 1985 GL1200 aspy.
One of the pulse generators had an intermittent error. With time, it became worse. I replace the pulse generator set and problem gone. Pretty difficult to find, especially as I reasoned that 2 cylinders oughtta fire if one pulse generator worked. Wrong assumption. On the 1985, one dead pulse generator means no ignition. So check the spark when it's dead. Did take me a long time to figure out.
Good luck
Per
May 29, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
Do u know the firing order for a 89 suzuki
89 Katana uses two coils, one fires cylinders 1 and 4 together and the other fires 2 and 3 together. It's a waste spark system. So your firing order is either one coil or the other every revolution.
May 02, 2010 | 1989 Suzuki GSX 750 F (Katana)
Need fire order,spark plug wires replaced in incorrect place
For several engines....
Fig. 1: Buick-built 231, 252 V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
Fig. 2: Olds-built 260, 307, 350, 400, 403, 455 Pontiac-built 265, 301, 350, 400, 455 V8 Engine Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Counter-clockwise
Fig. 3: Buick-built 350 V8 Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Fig. 4: Chevrolet-built 267, 305, 350 Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: clockwise
Fig. 5: Chevrolet-built 262 Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
Hope helped with this (remember rated this help) Good luck.
Nov 05, 2009 | 1985 Oldsmobile Delta 88
Spark plug order to distributor
For a 1985 Chevy S10 with a 2.8L engine the firing order is: 1-2-3-4-5-6 The Distributor rotation is clockwise.Take off the cap and bump engine till the rotor points to the no. 1 plug. this is the no.1 contact on the cap. follow rotation around the cap in order. {ie. 2,3,4 ect.} hope this helps.
Oct 12, 2009 | 1985 Chevrolet Chevy
Sport & Outdoor - Others Logo
95 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
