Question about Singer 2250 Tradition
I cant get my bobbin to thread i have followed all the instructions it seems that the needle just isnt picking it up
  • 320 Answers
Try to adjust the needle , enough to catch the bobbins thread and not too close to avoid breakage. The needle might be in a higher setting.
Posted on Nov 04, 2010
Thread on bobbin does not attach to needle when needle is turned down.
Depends what was causing the noise. It could merely have been the build-up of lint and thread. However, something else could be the cause.
First: Install a brand new needle. A bent, damaged, old needle will frequently cause noise because it is striking something it should not. A dull needle will also make a thunking sound as it tries to penetrate the fabric. The needle should be changed about every 8 hours of sewing...a very inexpensive fix!
Also, be sure to following the oiling instructions (if any) in your manual. Use only fresh good quality sewing machine oil and apply only 1-2 drops in each spot as instructed.
If the top thread still fails to pick up the bobbin thread, it is likely the machine has been knocked out of time. Take it for service.
May 02, 2017 | Janome Sewist 525S Mechanical Sewing...
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
I have a singer 2263 and i have it set up. but my problem is that i cant seem to make it pick up the bobbin thread with the needle. i have been following instructions but the thread binds up around the...
Have you pulled up on your top thread as it loops the bobbin thread? You are supposed to hold on to your top thread with your left hand and then lower your needle with the handwheel, you have to turn the wheel towards you not away from you or else you can mess up the timing. You will see it catch the thread and you will know to pull it up.
Sep 21, 2010 | Singer Sewing Machines
Needle will not pick up bobbin thread
Chances are you will need to retime it if you have checked everything else, if you email me with your make and model I can attach instructions
Mar 26, 2010 | Sewing Machines
Needle not picking up bobbin thread on Prolectrix 8 stitch
my machine is not picking the thread from down bobbin thread ,i am fallowing the all instruction for threading.
Jul 21, 2009 | Sewing Machines
Needle will not pick up thread from bobbin on a Brother's machine
This is going to sound silly but its one of the first things I check for... make sure that the needle is in correctly make sure that the flat side is towards the back as you place it in the needle clamp. better yet take the needled out all together and put a new one in just to be sure that it isnt bend
Jul 13, 2009 | Brother LS-2125 Mechanical Sewing Machine
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Machine wont pick up bobbin thread
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
Mar 11, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 2250 Tradition Logo
122 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
