Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
I have 2 x 2gb ram but only comes up as 2.5gb total on system
  • keithm25 Jun 13, 2008
    will try xp pro 64 bit and thank you very much for your help
    Problem Solver:
  • 17 Answers
I take it you have Windows XP Home, this is the total amout that will show under this operating system. The only way to optimize your system to utilize 4gb of ram will be to upgrade to a 64 bit version of XP Pro or (scary to say) Vista (I don't recommend)
Posted on Jun 13, 2008
Can speed be improved
how much memory is currently in the computer? If less than 2GB, consider adding memory (RAM) to the 2G maximum which will help. Otherwise, you can only clean out unnecessary startup programs, make sure your hard drive is not too full (keep at least 5GB hard drive space frr) and defragment your hard regularly. Also, check for malware and adware - try malwarebytes (malwarebytes.org) to clean out malware that slows down systems. Use the FREE version.
Jul 08, 2012 | Dell Inspiron Mini 1012 Netbook...
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
Do u have a 5gb for 80$with wi fi
in the market , the 5gb RAM costs 90 to 100$. I do not have a 5gb RAM nor 4gb RAM, but I only have 1GB RAM on my computer in which is not for sale... you can check google for the price list of 5GB RAM
Dec 16, 2010 | Computers & Internet
Total amount of ram allowed ???
If I've got the right manual (which I'm sure it is but do double check) it says total allowed is 2GB.
http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
Oct 31, 2010 | Intel D845GVSR Motherboard
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
RAM issue
In total it supports 2GB Ram. More than 2 gb is not supported my MSI k9MM series boards
Jun 25, 2009 | MSI K9MM-V Motherboard
Install memory not showing total only half
Hey,
it should show in the bios as 2048.
looking at the details of the motherboard
Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 2 x DIMMs Supported RAM speeds 400 MHz
Got the right speed ram etc?
Thanks,
Ekse
Feb 20, 2009 | Computers & Internet
Added more ram from 2gb to 8gb but still say only 2gb
1fb3933.jpg the above will help u..the OS will not support the RAM you have hence its not showing..hope it heps!
Nov 23, 2008 | Dell XPS™ 600 PC Desktop
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
81 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
