Question about Brother MFC 8500 All-In-One Laser Printer
Brother MFC-8500 Fax Error 77
When trying to receive a fax, I get "Error 77". I've unplugged it from the outlet and from the phone jack and when plugged back in, it says the same thing. Please help!!
  • 134 Answers
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Posted on Jun 14, 2008
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Mar 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
My MFC 8500 brother fax machine reports poor line condition when i try to use it with Magic Jack. Is there a solution?
You might try a better/faster internet connection or a faster computer to run it off of. VOIP phones have troubles handling faxes for this very reason.
Mar 09, 2010 | Brother MFC 8500 All-In-One Laser Printer
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error 77
related to a fuser error. Unit is detecting a too high or low heat internally. Try turning off for a few minutes. If error returns check voltage level at outlet or try a different outlet. Maybe too many items plugged in same outlet. If error returns, may need new fuser or thermistor.
May 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
429 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
