Question about Microwave Ovens
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can easily get fixed? Erika
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 305 Answers
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Posted on Nov 04, 2010
Model # JVM1870W07-what is the easiest way to change these-was able to get the bulbs out-but can't the new ones in-hard to see the holes from the back
HELLO.The easiest and only solution is given below.
things you need
  • Phillips screwdriver
  • 40-watt replacement bulb
    1 Unplug the microwave and open the door.
2 Remove the screws from the front grill and pull it off of the oven. The screws are located on the underside of the grill.
3 Pull the light bulb housing toward you through the access panel.
4 Unscrew the old light bulb and replace it with the new 40-watt light bulb.
5 Rotate the light bulb housing toward the back of the oven. Reattach the grill with the screws and plug the microwave back into the electrical outlet.
Thanks.
Sep 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
I have a magic chef that has microwave grill conventional oven every thing works except microwave don't heat
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 29, 2010 | Magic Chef MCD1311ST Microwave Oven
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Turns on but doesn't heat only a year old LG LRM1260SW 1200 Watts Microwave Oven
I have had the LG model lrm1260sw microwave for 3 years. Recently it quit heating. I found the problem was the soldered grounding lug connection on the power transformer had lost circuit continuity and failed. One of the secondary coils on the power transformer, red wire / bare copper wire, is connected to ground / chassis. I cleaned the lug connection and added a length of wire twisted together with the bare copper coil wire and soldered to the grounding lug. I then grounded the extra added length of wire to another chassis ground point. Make sure the transformer to chassis mounting screws are tight also. Now the microwave oven works like new again.
Feb 27, 2010 | LG LRM1260SW Microwave Oven
How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Nov 23, 2009 | LG LMV1630ST Microwave Oven
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
How do you replace the handle on my advantium 120 oven
If it's just the bottom one and you don't want to disassemble things to reconnect things right, drill a pilot hole in at an angle through handle and door to permit screwing in a wood screw to fix it up.  Brutish, yet sexy.
Dec 13, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
112 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
