Question about IBM ThinkPad T43 Notebook
My thinkpad t43 is no display now. i can't access bios.
Tech_Mania
  • 239 Answers
SOURCE: forgot password and cant enter bios with out it
BIOS password is stored in c-mos battrey...A small battery in the motherboard.....if u take out the battery and put it again.....The password will b lost....and then it won't ask for bios password...
Posted on May 04, 2009
benwabnick
  • 2404 Answers
SOURCE: my ibm thinkpad t43 displayed a message "hard error d0014"
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Posted on Jun 04, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
bschilz
  • 2049 Answers
SOURCE: ThinkPad T43 Hinge Replacement Instructions
Here is a link to the Hardware Maintenance Manual from Lenovo which should help...
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
Here's a link to the Service and Troubleshooting Guide
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2332.pdf
Posted on Oct 28, 2009
  • 23 Answers
SOURCE: My IBM ThinkPad T43 will not accept my BIOS
You will need to contact the manufacturer for this one.
Posted on Feb 10, 2010
IBM thinkpad t43 how do I access safe mode when I am the BIOS
Exit the BIOS and boot up the T43 and then press F8 function key several times. You can then select Safe Mode from the list of boot options.
Dec 05, 2011 | IBM Computers & Internet
How to reset ibm t43 bios pass
The BIOS password is setup in the BIOS configuration. If you have forgotten the BIOS password then it can be removed with difficulty. Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Oct 28, 2010 | IBM ThinkPad T43 Notebook
Hi i have ibm thinkpad t43 how can i bios unluck
remove the battery from the motherboard for 5 seconds then put it back thats all
Aug 19, 2010 | IBM ThinkPad T43 Notebook
I have a thinkpad T43 my screen keeps going in
enter the bios and go into advanced settings(if i remember right its page two) select lcd screen for maiin and secondary display and it should stop it reverting to the external display(which is the reason you have to hit FN +F7)
Dec 29, 2009 | IBM ThinkPad R40 2722 Notebook
T43 upgrading bios
The bios needs an operating system to work. That's why it's called an operating system. DOS will even work but, you must have something.
Jul 31, 2009 | IBM ThinkPad T43 Notebook
T43 speaker not work, use ear phone is ok, any
go into your laptop's Bios and check that the speaker are not muted in the Bios
Jun 24, 2009 | IBM ThinkPad T43 Notebook
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Bios not starting
Hit F1 to open Bios settings try to boot from bootable CD
Apr 21, 2009 | Lenovo ThinkPad T43 Notebook PC
How toremove ibm thinkpad t43 password
HI,
KINDLY SEND THE STEPS FOR REMOVE THE BIOS PASSWORD
REGARDS,
RAAJAA,
Sep 12, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
164 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
