Question about Stoves 720EF Electric Double Oven
Fan oven is dead
The top oven works fine but the fan oven (bottom) has no life. No light either. If the element has gone, I guess the light would still work. Do the 2 ovens have seperate fuses inside? If so, could you tell me where I might find it please? Thanks!!!!!
  • 250 Answers
When you turn to oven thermostat on, does the dial illuminate? All the information you need is in the handbook. If you don't have a copy, supply an email address and you can then gain access to by BT Digital Vault where a copy is stored for you to access.
Posted on Feb 04, 2010
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
Smeg se280x has just gone dead in middle of cooking .the digets have gone and is blank the oven fan @ light still work but that is it regards paul ?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 18, 2011 | Smeg SE280X Stainless Steel Electric...
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Stoves 720EF Electric Double Oven Logo
91 people viewed this question
Top Stoves Ovens Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
