Question about 2wire 2700HG-B Router (2700HGB)
Receiving packets on my home network, my notebook will not received packets, will send not received, i inserted my wep key, it also says i'm connected, and signal strength is ecellent
  • 4 Answers
Check your antivirus program, run it, check if you can get internet, if is Windows Vista you problably needs to reload the system, before try to connect other computer, make sure your router is ok. you can turn it off and back on.
Posted on Jun 13, 2008
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
Network can send packets cannot receive packets Modem and Cable checked out okay with another computer ethernet working okay. Windows xp home on dell dimension 5100. cannot ping to internet.
You can contact The Best Pc Doctor team for any technical help. Their contact details are given below.
www.thebestpcdoctor.com
877 407 9229(Toll free)
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I can receive SMS text from everyone but my wifes. I can send them to her and she receives them.
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 26, 2011 | Cell Phones
I need to know my wep key or ssid codes, whats the difference? i need it to set up for my ps3 online
WEP (wired equivalent privacy)
The privacy protocol specified in IEEE 802.11 to provide wireless LAN users protection against casual eavesdropping. WEP refers to the intent to provide a privacy service to wireless LAN users similar to that provided by the physical security inherent in a wired LAN.
When WEP is active in a wireless LAN, each 802.11 packet is encrypted separately with an RC4 cipher stream generated by a 64-bit RC4 key. This key is composed of a 24-bit initialization vector (IV) and a 40-bit WEP key. The encrypted packet is generated with a bitwise exclusive OR (XOR) of the original packet and the RC4 stream. The IV is chosen by the sender and can be changed periodically so every packet won't be encrypted with the same cipher stream. The IV is sent in the clear with each packet. An additional 4-byte Integrity Check Value (ICV) is computed on the original packet and appended to the end. The ICV (be careful not to confuse this with the IV) is also encrypted with the RC4 cipher stream.
WEP has been widely criticized for a number of weaknesses:
Key management and key size
Key management is not specified in the WEP standard; without interoperable key management, keys will tend to be long-lived and of poor quality. Most wireless networks that use WEP have one single WEP key shared between every node on the network. Access points and client stations must be programmed with the same WEP key. Since synchronizing the change of keys is tedious and difficult, keys are seldom changed. Also, the 802.11 standard does not specify any WEP key sizes other than 40 bits.
The IV is too small
WEP's IV size of 24 bits provides for 16,777,216 different RC4 cipher streams for a given WEP key, for any key size. Remember that the RC4 cipher stream is XOR-ed with the original packet to give the encrypted packet that is transmitted, and the IV is sent in the clear with each packet. The problem is IV reuse. If the RC4 cipher stream for a given IV is found, an attacker can decrypt subsequent packets that were encrypted with the same IV or can forge packets.
Weakness: The ICV algorithm is not appropriate
The WEP ICV is based on CRC-32, an algorithm for detecting noise and common errors in transmission. CRC-32 is an excellent checksum for detecting errors, but an awful choice for a cryptographic hash. Better-designed encryption systems use algorithms such as MD5 or SHA-1 for their ICVs.
Authentication messages can be easily forged
SSID (Service Set IDentifier)
The SSID (Service Set IDentifier) is a token which identifies an 802.11 (Wi-Fi) network.
The SSID is a secret key which is set by the network administrator.
You must know the SSID to join an 802.11 network. However, the SSID can be discovered by network sniffing. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID Security Issues
The fact that the SSID is a secret key instead of a public key creates a key management problem for the network administrator. Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Disabling SSID Broadcasting
Many Wireless Access Point (WAP) vendors have added a configuration option which lets you disable broadcasting of the SSID. This adds little security because it is only able to prevent the SSID from being broadcast with Probe Request and Beacon frames. The SSID must be broadcast with Probe Response frames. In addition, the wireless access cards will broadcast the SSID in their Association and Reassociation frames. Because of this, the SSID cannot be considered a valid security tool.
An SSID by any other name
The SSID is also referred to as the ESSID (Extended Service Set IDentifier).
Airsnort, Aircrack 2.1, Cain & Abel are some of the wireless packet sniffing tools which can decode the authorization key.
Dec 23, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My desktop won't connect wireless to the internet after installing a dlink dwl-510 wireless card, its says the installation was successful but when i try to connect to my network by puting the network key...
First make sure your modem is wireless, if it is not, you need to purchase a wireless router that connects to your modem. If that is all in place and you still have no connection, you may have to unplug modem and or wireless router for 30 second then replug back in, wait a few minutes, then try to get on line, if that does not work, go to the desktop, go to start, then to run command, punch in cmd, then enter, a black screen should appear, type in ping then a space then your ip address, like mine is 169.254.2.63 if you don't know it call who you have for internet service, ask them for it, that said press enter, you should receive a message saying 4 packets sent 4 packets received 0 loss, this now means your connection is good, and you should be able to go online, also within windows is a network troubleshooter, you can go there: start:control panel: network settings.also one other big reason it could be also is that your modem is secure, and has a wep key, you need that to make a connection, the wep key is printed under your modem, write it down. Then go to internet explorer like you are going online, now look on the task bar all the way to the right, right click the little computer scrren go to open network connections, strat a new connection, follow the prompts, and when asked put your wep key in.
Sep 24, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
Wep key
it all depends. There is usually a way to set it if you connect directly to the router, with a cable, then open up the website 192.168.1.1
When you open that up, you will basically be viewing your router's web page, and in the wireless security settings you can manually set your WEP key. these settings are in different places for different routers, but that's the general idea.
Aug 10, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Wireless laptop finds signal, connects to network but no internet
just a thought but may be you can try to remove the WEP/WPA and select the connection mode based on MAC id, hope it was some help
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
I am connected to my wireless network from my advent 4211 notebook, but I am not receiving any packets back from my dlink dkt-710 router. If I configure the internet protocol to automatically obtain ip...
FIRST you check for any security options enabled - like password or in the wireless advance settings you pefer to connect only to this network = make that to any wireless access point. The computer is sending packets but return packets will only comes through filters like firewalls or security measures definetly your problem belong to the security settings with your pc which is not accepting any outside devices to connect - check your firewall setting and under network properties check internet protocol settings also check your antivirus blocking the connection try to ping the wireless adpater ip of your pc by itself are your getting the reply???
Sep 26, 2008 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
57 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
