Question about Panasonic PT-51HX41 51" Rear Projection Television
Just received this model TV - broken, in pieces - worth pursuing?
I just received (free) a broken Panasonic 51" HD rear projection TV... it plugs in, powers on, and displays a picture. However, the blue bulb has been removed and I am told that the previous owner paid $50 for diagnosing the problem - the bulb allegedly needs to be replaced. However, I don't feel comfortable buying a new bulb and crossing my fingers that this is in fact the issue.
http://gallery.mac.com/natecovington#100008
I've searched online and it seems that the common problem with these things is the "convergence" circuitry/chips needing to be repaired/replaced:
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Panasonic-tv-color-alignment.htm
My question... what can I try (without bringing it into a shop) to further diagnose? Is this worth pursuing?
Model Number
PT-51HX41E
Chassis
AP820
Thanks!
-Nate
  • 2,071 Answers
Try to change those two STK 392-110 & 150,,try this option...
Posted on Jun 20, 2008
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Posted on Jun 13, 2008
Convergence Circuit Schematic diagrahm for my panasonic cinemavision rear projection HD TV? Picture of the convergence circuit on my circuit board.
I will need the model number of your set to assist you with your request. Please respond to this same post for assistance
Oct 21, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Do you have to add a converter box to receive free
You will need a converter box or a separate tuner. The TV has an NTSC (analog) tuner.
I hope this helps.
(the $40 boxes that are available are mostly SD. You should check the specs if you want a HD tuner.)
May 30, 2010 | Hitachi 51SWX20B 51" Rear Projection...
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a rear projection panasonic 51" tv with blue curved lines
This can be repaired by a Degaussing coil from most TV repair places. If you haven't already you should shut down the TV and wait till it cools maybe 1 hour or so and then when you turn it on there should be a degaussing circut that might clear this up for you build into the set. Its not that strong a signal and usually takes care of minor discolorations. If it doesn't have that then a shop can come and take care of it pretty fast usually.
Mar 29, 2009 | Panasonic PT-51G36 51" Rear Projection...
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Dec 27, 2008 | Hitachi 51F510 51" Rear Projection...
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
