Question about Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre x9g naga V
I need to know the value of c65 in order to replace it, and is there a list of components for the parts on the power supply board
1000uf 16 VOLT
Posted on Sep 27, 2008
Sceptre x9g naga v
May i know the exact detailed model/maker of your unit...?
Jun 13, 2008 | Computers & Internet
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the...
It may have dying power supply due to bad DC filter caps like the 17" version.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
I have a Sceptre X9G-Naga II and two ceramic capacitors that are in the power supply are fried. The capacitors are C11 and C12. Anybody knows the value of these capacitors and where Can i get them?
I think they are MOVs in the primary AC side. Can you post the pictures, or send them to me at budmrtn@aol.com. Most MOV are blue in color, ceramic cap is usually orange/yelllowish color.
Nov 10, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
My Sceptre X9G Will Work for a 10 mins or so then starts to Cycle on and off sometimes every few seconds and sometimes for 10 mins or so. I have changed power and video (15pin D Vid) cord. Connecting to a...
You have a power supply that is about to die. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 18, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9G-NagaV
I had a word with a technician of these boards, and R88 and C63 are factory removed.
Jan 28, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Scepyre 17 in X7
This board is out of my Sceptre X9G Komodo. The 740uf capacitors are clearly marked 25V. The 1200uf Caps are 10V. I ordered parts for mine to try. The darker 740 has a slightly "popped" top.
470 is about 10mm dia X 16-17mm long
1200 is about 10mm dia X 20? long
two leads on each about 5mm apart. They are soldered to the board.
Jul 16, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
X9g komodo v screen just turned blank (white)
Go to ebay, type X9g kimidi logic board. Usually, some seller might have pulled working parts from other monitors and sell them individually. If you cannot find them, google "buy x9g komodo logic board". Some website, I'm quite sure will sell them.
Mar 17, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-NagaIV 19" LCD Monitor Logo
284 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
